9 Volt Battery Noise Module PRANK
Intro: 9 Volt Battery Noise Module PRANK
This is a 9 volt battery module that will make very annoying noises. Hide this small device anywhere and annoy the crap out of your friends. Let's get started :)
STEP 1: Take Off the Top
Take the top off a 9 volt battery with some pliers or anything you want to use.
STEP 2: Put the Wires On
Twist the wires onto the back of 9 volt battery clip you just made.
STEP 3: Tape the Wires
Tape the wires so they stay in place
STEP 4: Attach 1 Wire
Attach one wire from a color changing LED to one of the wires on the clip. Make sure it's the right wire or it won't work.
STEP 5: Attach the Speaker
Attach the speaker to the two wires that you have left. Now the circuit is complete.
STEP 6: Now Tape It All Down
Tape the circuit down and make sure the wires don't touch.
STEP 7: Take It Off
I had to take off the top of the speaker because it wall blocking the sound.
STEP 8: It's a Small Device
It's so small so u can hide it anywhere.
STEP 9: It's Finished
Now that it's finished you can go and hide it. The newer the battery the higher the sound frequency.
8 Comments
DolphinAirlines 8 years ago
If i use an led what resistor should i use because the led probable will burn out quick if you don't use one.
John_Singleton_ 8 years ago
The battery i used was quite drained so i don't know actually. sorry
Peregrine05 5 years ago
If your battery had 7 volts, try a 220 ohm resistor.
Derp4Days 8 years ago
oooooh, this will SO irritate the crap out of my friend!!! xD
mr.ante.sepulveda 8 years ago
ScottaBlanchat 8 years ago
Sorry i forgot to put that in
