A Bowl From Recycled Chair Slats
Introduction: A Bowl From Recycled Chair Slats
About: I am a Marine Engineer in the RNZN (41 years done in various navies) and am looking forward to retirement!!! so I can do more messing about with tools
It's lockdown time again in NZ fortunately only for a week, but didn't have any time to buy in supplies for some projects so I have to use what I have around.
This bowl is made from slats rescued from a broken garden chair found in a skip
Wooden slats
Wood glue
Sand paper
Olive oil
Tools
Band saw
Lathe
Step 1: Prepare the Blank
I had wood from an old garden chair
Possibly teak, more likely kwila but a nice tropical hardwood, too nice to go to landfill
So I sanded them and cut to size
Step 2: Glue Up the Blank
I left the rounded sides as I wanted voids in the bowl
Step 3: Cut the Blank and Screwed on Backplate
I used my band saw to cut the blank roughly to shape
Step 4: Turn the Outside
I turned the outside shape that I wanted and sanded smooth
Step 5: Turned the Inside, Cut Off From Backplate
Once I had turned and sanded the inside I cleaned out all the void areas with a small drill bit
Step 6: Turn Around in Lathe
I cut a sacrificial piece of plywood which I glue to the base with a piece of paper in between to make separation easier (I was told this about 50 years ago at school) means there are no screw holes in the wood
Then remounted it in the lathe
Step 7: Finish Coat
I haven't decided on a use yet so coated with a food safe oil (olive oil) to bring out the wood colours
Sculpt & Carve Challenge
Be the First to Share
    • Halloween Contest
      Halloween Contest
    • Teach With Tinkercad Contest
    • Cheese Challenge
      Cheese Challenge
    2 Comments
    buck2217
    buck2217
    Reply 1 year ago
    Thanks
