Introduction: A Candy Ziplinerator 2000
I made this because i'm tired of having to get up and walk 5 steps to get a piece of candy. Now you don't have to with the Candy Ziplinerator 2000. It zip-lines your candy to you.
Step 1: Materials
1.) Any kind of mini piece of Candy.
2.) 18” dowel rod.
3.) 5 ¼ ”x 2 ½“ x 1 ½” wood pallets x2.
4.) 8’ 3” of string.
5.) 1 paper cup.
6.) Multi-tool.
7.) Scissors.
8.) Hot glue gun and hot glue.
9.) Ruler.
10.) Drill with bit the size of the diameter of the dowel rod.
Step 2: Step 1) Cut Dowel Rod to Correct Lengths With Multi-tool.
Use the multi-tool to cut the dowel rod to two lengths, 1’ and 6”.
Step 3: Step 2) Drill Hole in Wood Pallets the Size of Dowel.
Step 4: Step 3) Hot Glue 1’ and 6” Dowel Rod Into the Wood Pallets.
Step 5: Step 4) Cut String to 8’ and 3”.
Step 6: Step 5) Tie String to Each Pole.
P.S. Double loop the string so that it is 4’ long.
Step 7: Step 6) Hot Glue String to the Side of Cup.
P.S. Try to have the string around the other string when gluing.
Step 8: Test It Out!
It WORKED!
