A Few Ways to Hide Data on a Computer
Intro: A Few Ways to Hide Data on a Computer
If you're interested in coding or batch scripting, check out my latest Ible here.
A lot of people can't do more with a computer than type a Word document or make a "picture", so called, on Paint. Of course most people reading this instructable will know a bit more about Windows than that. But even people whose knowledge is limited to browsing the Web have digital secrets they would like to conceal from prying eyes (and chances are, the more you know about computers and related items, the more you will have to hide). This -ible is meant to give a few ideas to people who can really use computers about hoarding information, teach people who know the basics a few ways to hide sensitive data, and perhaps inspire the computer illiterate to learn something (though the last group will most likely never get a chance to read this page).
You need:
> A Computer
> A Little Bit of Your Time
> A Little Patience: this is my first instructable.
You need:
> A Computer
- This instructable is not meant for people who are so completely "computer illiterate" that they do not understand computer basics, such as how to navigate directories, save documents, etc. If you have trouble saving a Word document to your desktop instead of My Documents, I advise you to learn the simple things first (just opening My Computer and browsing folders is surprisingly informative) before continuing here.
STEP 1: Making a “Hole-In-the-Wall”
This is a very useful way to hide things from view, but if a nosy user searches for material hidden in this folder (yes a Hole-In-the-Wall is simply a folder) the material will emerge from hiding. These folders are very useful for storing Caches, Strongboxes, and Crates, which you will learn about later.
Open C: and navigate to some little-opened directory. My favorite is C:\WINDOWS\system32, but you could build a Hole anywhere in the Master Drive (or any drive, really). Program Files is another good place; just build the Hole in the files of some random game. Once you have your "Wall" create a new folder (right-click, New, Folder) and name it. If you really want, you can name it "My Hole-In-the-Wall where I store my secret files" but this defeats the purpose. A Hole is supposed to be inconspicuous, so it is best to name it something like "sat" or "pta" (this is why WINDOWS is a good place; it is full of folders with names like "oobe" and "ras"). Now, simply put your files into your new hiding place and leave them there. It is a good idea to change the names of these files if they are really incriminating: use numbers or symbols, or even type the names backward; this way someone poking through your C: won't be tempted to open them if they do stumble upon your Hole-In-the-Wall. Now just memorize the file path and you have a secret folder!
- Search Instructables for "How To Make An Invisible Folder". This is useful too.
STEP 2: Building a “Crate”
This method will only allow you store text, whether a sensitive document or the source code of some program. Simply type or paste text into NotePad and save as Whatever.jpg, then change "Text Document" to "All Program Files" and save somewhere. This exports your text into a JPEG picture file. You can also save them as Bitmap (.bmp), PNG (.png), or GIF (.gif) images; simply replace ".jpg" with ".bmp", ".png", or ".gif". If you try to open a Crate with an image viewer, the program should just say something like "No Preview Available", so to retrieve the Crate's contents, you have open NotePad, select File, Open, and navigate to the directory your Crate is located in. Just as you did to build the Crate, change "Text Document" to "All Program Files", and then select your Crate and click "Open". Now you can view, edit, or copy/paste the text concealed inside. Again, it is a good idea to name this file something inconspicuous and store it someplace safe, where your sibling won't "accidentally" delete it.
STEP 3: Constructing a “Strongbox”, Part 1
This follows the same idea as a Crate, in that it stores data inside another file, but a Strongbox is password protected. This involves batch, which you can easily learn about from the countless "How-To-Do-Batch" instructables on this site. Simply copy/paste the following into NotePad:
@echo off
set key=*****
title ::
color 0a
echo Please enter your password.
set/p "pass= >"
if %pass%==%key% goto UnPack
cls
color 0c
echo That is not the password! Aborting unpack!
echo.
pause
exit
:UnPack
set dest=C:\Contents.txt
cls
echo That is the correct passord!
echo.
echo Your data will unpacked and sent here: %dest%
echo.
echo Please make sure this file does not already exist befor continuing
echo as this may ruin your data.
echo.
pause
cls
echo $$$$$>>%dest%
echo Unpack complete!
echo.
echo Your data can be found here: %dest%
echo.
pause
exit
@echo off
set key=*****
title ::
color 0a
set/p "pass= >"
cls
color 0c
echo.
pause
exit
:UnPack
cls
echo.
echo.
echo.
pause
cls
echo $$$$$>>%dest%
echo.
echo.
pause
exit
STEP 4: Constructing a “Strongbox”, Part 2
At the top of the script you will see "@echo off", followed by a space. Below this is a line that says "set key=*****". Replace "*****" with the password that will unlock the Strongbox. This password can't have any spaces, so use an underscore ( _ ) to separate words.
Ex: set key=Hello
set key=unlock_this_box
Also, make sure there is no space between "key=" and your password.
Now the annoying part: packing the contents. Eight lines from the bottom of the script you will see a line that reads "echo $$$$$>>%dest%". "$$$$$" represents a line of text. Type or copy/paste a strand of text here.
Ex: echo Hi>>%dest% (notice the dollar signs are replaced by "Hi"
echo I am really a potato in man's clothing.>>%dest%
For every line in your document you must place "echo" before your words and ">>%dest%" after them (it is much easier to copy "echo $$$$$>>%dest%" and paste it once for each line, and then go back and insert your words).
Ex: echo Potatoes are not geniuses.>>%dest%
echo El Mano is a genius.>>%dest%
echo Therefore, El Mano is not a potato.>>%dest%
Ex: set key=Hello
- Make sure not to change ">>%dest%" or the program won't unpack correctly.
- I can't get this to work with pictures, sounds, executables, movies, and the like. If you have any suggestions or ideas, please post them.
STEP 5: Creating a “Cache”, Part 1
Crazy Leprecaun has an entire -ible on this process (which you can find here: https://www.instructables.com/id/How_to_Hide_Files_Inside_Pictures/), but I wrote a batch file that makes it a little easier than using Command Prompt. This simply stores an archived folder inside a picture. First, copy/paste the following script into NotePad and save as a batch program (name.bat, All Program Files):
@echo off
title Cache Creator[
color 07
:InA
cls
echo Cache:
echo Contents:
echo Destination:
echo.
echo Please enter the name of the Cache.
echo (must be an image, must contain no spaces)
echo.
set/p "cache= >"
if Exist %cache% goto InB
cls
echo The file could not be found.
pause
goto InA
:InB
cls
echo Cache: %cache%
echo Contents:
echo Destination:
echo.
echo Please enter the name of the Contents.
echo (must be a zipped file, must contain no spaces)
echo.
set/p "contents= >"
if Exist %contents% goto InC
cls
pause
goto InB
:InC
cls
echo Cache: %cache%
echo Contents: %contents%
echo Destination:
echo.
echo Please enter the Destination.
echo (must contain no spaces, must have same extension as Cache)
echo.
set/p "destination= >"
cls
echo Cache: %cache%
echo Destination: %destination%
echo.
echo Do you wish to build a Cache? y/n
set/p "com= >"
if %com%==y goto Hole
if %com%==n goto InA
cls
echo That is not a valid command.
pause
goto Select
:Hole
copy/b "%cache%"+"%contents%" "%destination%"
echo Cache created.
pause
goto InA
@echo off
color 07
:InA
cls
echo Cache:
echo Contents:
echo Destination:
echo.
echo.
set/p "cache= >"
cls
pause
goto InA
:InB
cls
echo Cache: %cache%
echo Contents:
echo Destination:
echo.
echo.
set/p "contents= >"
cls
pause
goto InB
:InC
cls
echo Cache: %cache%
echo Destination:
echo.
echo.
cls
echo Cache: %cache%
echo.
set/p "com= >"
cls
pause
goto Select
:Hole
echo Cache created.
pause
goto InA
STEP 6: Creating a “Cache”, Part 2
Now follow Leprecaun's instructions: compress the files you want to hide in an archive such as "Archive.7z" (7z Portable is a very good archiver; WinRar is too, but you have to buy it). The file-to-be-hidden MUST be an archive if you ever want to retrieve its contents! Second, choose a picture to be the Cache; I like using PNG and BitMap images, which you can easily make using Paint. Place both your archive and your image in a directory with no spaces (C:\z), and run Cache Creator. Type in the file path for your Cache (C:\z\Image.png) and press ENTER. Now type in your contents (C:\z\Archive.7z). You can't enter the archive before the image; if you do, the picture will not be displayed when you open the file and someone might delete your Cache, thinking it is a mistake. Finally, enter your Cache's destination, the place it will be created in, and make sure to include the same extension as the image you used. I use the same folder as my archive (in this case C:\z\Cache.png). Type in "y", hit ENTER, and you have a Cache! To retrieve its contents, open up 7z Portable/WinRar/Whatever, select your cache, and hit "Extract". If you password-protected your archive (a very good idea) you will have to enter the password. The resulting files should be exactly the same as the ones you buried in your Cache.
STEP 7: Putting on a "Mask"
A Mask is simply a file that has been renamed, so it won't function in a way that someone will want.
To make one, open Command Prompt and type "rename *YOUR FILE HERE* *THINGIE.EXTENSION*"
Example: rename C:\MyProgram.exe C:\MyProgram.txt
Not only does this change the file's name, it changes the extension. Instead of opening "MyProgram" as an application, the computer will use NotePad/WordPad to view it. It is now hidden from plain sight. To return it to its original state, once again type "rename *YOUR FILE HERE* *THINGIE.EXTENSION*", and give the file its original extension (in this case ".exe") once more.
rename C:\MyProgram.txt C:\MyProgram.exe
You can rename any file/program/document so it pretends to be anything else. Changing something to "Name.fil" or Name.dat" is a good way hide it, as Files and Databases are difficult to open without the right software.
This rename thing has another incredably useful trick: you can use it to email things that your provider wouldn't normally allow. My email (Gmail) doesn't allow the sending of Executables for security reasons, but you can rename an Executable as a text file or something, and then attac/send it. The reciever can then simply rename it ".exe".
STEP 8: Building a “Storage Bin”
A Storage Bin is a hidden, password-protected folder you can use to store whatever you want. To my knowledge, the contents of this folder are search-proof, making it perfect for hiding things others know you have. This hiding place is very easy to make: just download and run the attached file; it will walk you through the setup process. Use your new Storage Bin to hide sensitive documents pictures, programs, or whatever.
- Storage Bin Creator is not a virus. If for some reason it harms your computer in any way, I'm extremely sorry. It's a compiled batch file with no other purpose then to create a hidden folder and a PadLock file to open it.
STEP 9: Nothing Is Ever Secure!
I hope this Instructable was worth the time you spent reading (and perhaps experimenting with) it. If you have any comments, questions, ideas, or useful facts, please post them.
Several people have commented that these methods of concealment would never hide anything from the police/FBI/CIA/NSA/Computer Technicians. This is very true. To quote myself, nothing is ever, ever, completely secure. If you can access something, there are probably six ways to crack, trick, or manipulate it. These are ways you could hide things from nosy family members, coworkers, and/or friends, ways to hide things like the family picture you use to blackmail your brother, and the book you're writing but are too embarrassed to ever let your mom see. If you really want to hide something, use TrueCrypt (look for Instructables adout it; I didn't mention it because I really haven't figured it all out yet).
I wrote this Instructable as a way to help people who need to hide data but don't know how. I can't control what you do with this information, but please respect me, my ideas and yourself and don't use it to hide anything thoroughly sordid.
El Mano:
Build your own CMD Prompt
Keep your Eyes working Great
This simple health switch will Keep you Warm
Wreak Havok with this simple Computer Virus
El Mano:
42 Comments
shieldmaiden09 7 years ago
I made a "Hole-in-the-Wall", but when I tried to save something to it I was told that I don't have permission to save in the location (C:\Program Files). I did some Googles to see if there was a way around this, and couldn't find any good answer. Could someone please help me on this? Thanks.
Luigi Pizzolito 8 years ago
Cool!
gattler 8 years ago
1. do we use Storage bin creator1 or 2?
2.neither of them make the padlock file....
CJingyansu 9 years ago
Excellent tips, i must say. I have also mentioned a few things one must consider hiding from his/her desktop. http://techyuga.com/things-you-need-to-hide-on-your-computer/
Uthulyz 9 years ago
To get the .tmp to work I just changed the file extension to ".exe" and it booted no issue.
Thanks for the help too, Mano!
account3r2 12 years ago
I thought of that a long time ago and saw that it was on Instructables...
It is very cool though!
UnderManiac 12 years ago
You and your friends can communicate privately by typing your text and hiding it in a picture, send the picture and they can decode it. Don't modify the picture in any way after you encode it with text, or the text will become unrecoverable.
llamma1010 14 years ago
Saturn V 13 years ago
lpdunwell 12 years ago
Oroka 15 years ago
El Mano 12 years ago
nutsandbolts_64 13 years ago
RedFlash 14 years ago
DarklordNinja987 14 years ago
El Mano 14 years ago
By "multiple files" I'm guessing you want to get sveral identical text files unpacked, perhaps in seperate locations?
Where does this extra line appear?
echo Hello! I am a text file.>X.txt
echo This is a second line beneath the previous one.>>X.txt
echo The End>>X.txt
This would create a txt file with three lines, line one saying "I am a text file," and line three saying "The End."
To create multiple files:
echo I am file # 1>PATH\File_1.txt
echo I am file # 5345422A>PATH\File_5345422A.txt
