Introduction: A 'PEN' Pen Holder
Here I present you 'a pen pen holder'. It's made up of used plastic pens.
Plastic Pens
Hacksaw Blade/Knife (if necessary)
Glue
Step 1: SORT AND SORT
I have three types of pens here.
I removed the refills and caps of the pens and took the middle portion.
In one type I have to cut the nib from the pen using a hacksaw blade (a knife can also be used as an alternative)
Step 2: PAIR AND PASTE
I paired all of them as you can see, and glued each pen, and let it dry. It will be easier to attach them further.
Again I paired the already paired ones.
Then I attached the 4 by 4 in a curved shape, so that we get a circle shape at last.
Now, step by step attach the other paired pens too, so that finally it became a circle and let them dry.
Note: I didn't add any base to it. If you are trying this you can add a cardboard piece or anything for the base.
A Tip: You can attach those pens on the base eg.cardboard using glue, and attach pens together with that.
Step 3: Finally...
Finally, we get a round-shaped holder (You can make any shape you like).
I wrote a note and inserted it in two of those colourless pens I have.
Then I have inserted the pen's bottom to the top of the penholder, which is also an optional one.
SO THERE IT IS ... A pen holder made up of pens.... A 'PEN' PENHOLDER!
Plastic Challenge
