A Quick Pie Crust
Intro: A Quick Pie Crust
When you want pie, you want pie. My Grandmother's no-chill pie dough is a quick pie crust recipe which yields delicious results FAST.
I got home late and needed to whip together a quick meal for a dinner party. I made a no fuss chicken dinner and used this crust for a quick apple pie the other day. The whole meal took a little over an hour to prepare, and was quite tasty!
-Forkable
-Forkable
STEP 1: The Recipe
My Grandmother's no-chill pie doughis delicious, easy, and quick because you don't need to chill it for a couple hours before rolling out!
This recipe requires:
2 1/2 c. Flour
1 c. Shortening
1 Tsp. Baking powder
1/2 tsp. Salt
1 egg + 1/2 c. cold water
2 1/2 c. Flour
1 c. Shortening
1/2 tsp. Salt
STEP 2: Make Your Dough
Sift 2 1/2 c. flour with 1 tsp of baking powder and 1/2 tsp salt in a bowl.
Add 1 c. Shortening. (see tip below for measuring shortening)
My Grandma uses lard, but I am substituting shortening for this pie dough which works just as well and will keep much longer on a pantry shelf.
Using a pastry cutter or a large fork, fork till chunky.
Take a liquid measuring cup. Add 1 egg (best if at room temp). Add cold water to egg until mixture measures 1/2 cup. Use cold water only as it helps bind dough and keep dough solid when handling. Mix Egg and water together with fork.
Fork water and egg mixture into the dough.
Kneed dough together. Take loose dough and put in an old pillow case which I set aside to use only for baking (make sure you remove any lint from pillow case corners. I usually do this with pillow case inside out). Kneed dough in pillow case until a nice dough forms
Set dough aside to prepare filling.
**Measuring Shortening Tip:
A quick trick to measuring shortening to save mess when dealing with greasy stuff is to take measure it in water. Take a liquid pint measuring cup. Add one cup of water and drop shortening in. Add enough shortening until water measures at 2 cups. (You are measuring by displacing water). With spoon, grab shortening out of measuring cup and discard remaining water. In this way, you don't grease up a measuring cup and makes for an easy clean and saves time!
STEP 3: Roll Out Your Dough
The pie dough recipe is enough for two pie crusts. Cut dough ball in half to prepare your crust.
Make sure to flour your surface and your rolling pin and roll out your pie dough. Change angles while rolling to keep it the same thickness throughout. Keep your pie pan handy so you can test to make sure the dough is rolled large enough for your pan.
When your crust is the right size, roll dough around rolling pin and gently transfer dough to pie pan. Pat dough down into contours of pie pan.
Pie Rolling TIP:
Use a piece of parchment paper sprinkled with flour, roll out pie dough. I like rolling on parchment because you can spin it around easy to change your angle and you can lift the edge of the paper to ease your dough onto your rolling pin when you need to move rolled dough into the pan. Parchment paper is not expensive and found at every grocery store. It has many other handy uses in the kitchen so is always good to have around.
Pie Rolling TIP:
STEP 4: Finish Crust
Add your pie filling.
If you are making a crust top for your pie, repeat previous step to get your dough rolled out. Using a pastry brush, brush on egg mixture to help top and bottom crusts join.
Once your top and bottom crust are together or if you only need a bottom crust: Cut off any excess pie dough around the edges, leaving about a half an inch for decorative pinching.
Decoratively pinch to finish edges and make your crust very pie-like.
Brush remaining egg mixture on pie crust and your pie is ready for oven.
Done!
Here is a blog post of how my pie turned out.
Done!
44 Comments
JordynK3 5 years ago
MiniCitrus 5 years ago
I always just bake it at whatever temperature the recipe I’m using it calls for. I have an apple pie recipe I substitute this crust in for where I bake it at 400F, and a chicken pot pie recipe that bakes at 425F. Both turn out well. Probably anything around that range is fine.
ErinC113 6 years ago
This is my "go to" pie crust that everyone loves! I have always made my crust from scratch and this is by far my favorite. I have been using this recipie for years now and it has never failed to impress!
MiniCitrus 6 years ago
Just wanted to say that I used this recipe for the holidays last year, and I’ll use it again this year. It’s so easy, fast, and versatile! It’s not overly complicated or sweet, which takes the stress off of getting good food made and enhances the tastes of the filling. For anyone looking for a great crust recipe, try it.
PamelaA34 7 years ago
OMG, I'm never buying a pie crust again. I bought frozen (expensive!) pastry dough sheets for my blueberry pie cause I'm lazy and when I opened it it was moldy. I was so angry. So, I went online to find a quick pie crust I could make easily with stuff I had in the house and this one showed up. It is so forgivable and easy to work with. OMG. I've made lots of pie crusts and it is always tedious and never turns out all that well. I think the egg is what gives it the required structure in the way of protein so it doesn't fall apart. So easy to work with. I did lattice-work on top of the pie and it was a breeze. Thank you so much. You have my gratitude forever!
Melody12345678 7 years ago
I wanted to make pastry without having to spend ages chilling it this recipe has been really helpful.
LoRo8 8 years ago
This is a very good and fast recipe! I had to use half shortening and half margarine. I used it to make chicken pot pie. As you can see in the pic. I didn't bother trimming the excess pie dough - I just rolled it up and into the oven it went.
CosmicBrambleclaw 8 years ago
awesome instructable :D I was planning on making a apple pie myself last night but the Martha Stuart crust recipe I ended up using was a bust, and I couldnt find my chill-free recipe I used on my very first apple pie (my last one) but yours worked like a charm :D bookmarking this beauty for all my pie needs from now on :)
clairens 15 years ago
Robbob76 15 years ago
CynicalStick 15 years ago
zoundsPadang 13 years ago
Crisco (today) is actually vegetable lard, made of saturated triglycerides. It's almost like the butter version of vegetable oil. To make it, you simply break the carbon-carbon double bonds of vegetable oil into single bonds, adding Hydrogen atoms. This makes the structure smoother and less kinked, resulting in molecules that nest closer to each other, forming a solid white Crisco mass.
Triglycerides are nothing like polycarbonates, polyesters, polyethylenes or any of the chemicals we traditionally think of as plastics. In fact, the chemical structures differ quite drastically, with triglycerides being made up of three long fatty acids connected to a glyceride backbone and plastics being made up of single or branching strands of repeating units, usually containing six-carbon rings.
In addition, triglycerides and plastics are both generally thought of as a single molecule, like water or iron. To say that a fat is "one molecule away from ... plastic" is like saying that the Golden Gate is one bridge away from being the Brooklyn Bridge.
All this isn't to say that fully hydrogenated triglycerides are a health food. They are a lot worse for a person than other fats, but they are not "very difficult for our bodies to process" at all. Butter, on the other hand, has quite a lot of cholesterol mixed in with its triglycerides. Cholesterol is what really builds up in your arteries, and avoiding eating too much is a very important part of developing a healthy diet and lifestyle.
I hope this has been helpful, though organic chemistry is a very difficult topic. Remember not to fall into the naturalistic fallacy and assume that anything natural must de facto be better than anything altered by chemistry. Aspirin is a chemically altered version of the salicylic acid we originally found in tree bark, but it's a very safe and effective anti-inflamatory.
I wish Instructables had a like button, I'd spam it so hard for your comment
as a student studying Nutrition Science at NC State University, I can say that you are absolutely right (incase anybody was doubtful)
Brookly1n510 8 years ago
adawn4 12 years ago
Claudia Moema 15 years ago
ClayOgre 15 years ago
http://fitnesstransform.blogspot.com/2008/08/organic-lard-oxymoron.html
Forkable 15 years ago
