A Speedy Way to Make a Speed Boat Costume
Intro: A Speedy Way to Make a Speed Boat Costume
This costume was designed to be worn by middle school aged children; it is the perfect costume for school play, Halloween or dress up around the house. The costume is made of slotted cardboard, which makes it quite easy to assemble and disassemble. Because there are only three pieces, this is quite an easy costume to construct.
This was a school project done by ninth grade students in New Jersey. Our job was to construct an entire project out of slotted cardboard, so that we could learn how to do a project, and then present it. This project had to be marine themed and it had to be have a theme that went with our groups.
Design Brief- My group had to construct an entire costume out of slotted cardboard. The theme we picked was boats. I had to design a speed boat.
Specifications- It must fit a middle school student, be practical and comfortable. This costume should be something that middle school aged children wants to wear.
Limits- This costume must be made of cardboard and marine themed. It must be small enough to wear comfortably.
STEP 1: Prepare
ITEM MATERIAL DESCRIPTION QTY SIZE REMARKS - PART
S1 Left side Cardboard 1 5 ¼’ x 2’ Left Side of Boat
S2 Right side Cardboard 1 5 ¼’ x 2’ Right Side of Boat
S3 Back side Cardboard 1 2 ½’ x 2’ Back of Boat
Tools and Equipment list
ITEM TOOL USE
TI CUTTING MAT To protect the table while cutting
T2 UTILITY KNIFE To cut the cardboard
T3 RULER To measure the length of the sides being cut
T4 PENCIIL To draw lines before cutting
T5 PAINT (optional) To decorate the costume
Part List
ITEM QTY PART NAME
P1 1 Left Side of Boat
P2 1 Right Side of Boat
P3 1 Back of Boat
STEP 2: Obtaining the Materials
A Cutting Mat
A Utility Knife
A Ruler
A Tape Measure
A Pencil
Paint (Optional)
STEP 3: Finding the Cardboard
If making the boat to fit an average middle school child the best would be to obtain two separate pieces of cardboard:
One should be about 6'x 6', this will make the left and right side of the boat.
The other piece of cardboard should be about 3'x3', this will make the back of the boat.
STEP 4: Drawing the Left Side
Three pieces will need to be draw before cutting, the first one is the left side:
The left side:
Using the pencil (T4) draw a curved diagonal line from the bottom left corner to the top right hand corner, curving the right corner
Using the ruler (T3) measure in from the left side ¼’ and make a mark using the pencil (T4). Then measure with the ruler (T3) down from the mark, 1’, this will become a slot. Make sure the slot is the thickness of the cardboard being used.
Using the ruler (T3) measure in from the right side ¼’ and make a mark with the pencil (T4). Then measure with the ruler (T3) down from the mark, 1’, this will become a slot. Make sure the slot is the thickness of the cardboard being used.
Measure using the ruler (T3) in from the right side ¼’ and make a mark with the pencil (T4). Then measure with the ruler (T3) down from the mark ¼’, this will become a slot. Make sure the slot is the thickness of the cardboard being used.
STEP 5: Drawing the Right Side
The right side:
Draw with the pencil (T4) a curved diagonal line from the bottom left corner to the top right hand corner, curving the right corner
Measure using the ruler (T3) in from the left side ¼’ and make a mark with a pencil (T4). Then measure with the ruler (T3) down from the mark, 1’, this will become a slot. Make sure the slot is the thickness of the cardboard being used.
Measure with the ruler (T3) in from the right side ¼’ and make a mark with a pencil (T4). Then measure with a pencil (T3) down from the mark, 1’, this will become a slot. Make sure the slot is the thickness of the cardboard being used.
Measure using the ruler (T3) in from the right side ¼’ and make a mark with a pencil (T4) on the lower half of the cardboard. Then measure with the ruler (T3) up from the mark ¼’, this will become a slot. Make sure the slot is the thickness of the cardboard being used.
STEP 6: Back of Boat
Using the ruler (T3) measure in from the left side ¼’ and make a mark using the pencil (T4). Then measure with the ruler (T3) down from the mark 1’, this will become a slit. Make sure the slot is the thickness of the cardboard being used.
Measure using the ruler (T3) in from the right side ¼’ and make a mark using the pencil (T4). Then measure with the ruler (T3) down from the mark 1’, this will become a slit. Make sure the slot is the thickness of the cardboard being used.
STEP 7: Cutting the Pieces
STEP 8: Parts List
Parts List-
1 Left Side of Boat
1 Back Of Boat
STEP 9: Assembly
2. Insert the long slit of the right side of boat (P2) into the right slit of the back side of boat(P3)
3. Slide the short slits of the right side of boat (P2) into the short slit of the back side of boat (P1)
2 Comments
beckybella502 13 years ago
i love your costume, it is amazing
techproject 13 years ago
