Introduction: A Step Up for Natali
Two level step ladder with rail support.
perfect for unsteady balance and weak legs.
Step 1:
A - cut and weld two side frames using 30*20mm steel profile. 20*4mm steel is used for the rail seatings.
B - cut and weld 20*20mm steel profile for the step, and 30*20 for the inner legs as shown in the picture.
C - weld all parts together, keeping the step level. use 4mm steel to weld the back legs to the inner legs
D - add 20*20mm cross braces at the front, as shown.
Step 2:
B - cut and weld 20*20mm steel profile for the step, shown in the picture.
C - cut and weld 30*20mm steel profile and 20*4 bar, making the top rail seating.
D - weld all parts together, keeping the step level, adding the front cross bar.
Step 3:
A - We used 10mm mahogany wood for the two steps, cut to size.
B - The rails were also made of mahogany, 20*25mm with rounded adges, cut to length.
C - Screw and glue all the wooden parts to place.
D - Assemble all parts with arm hinges, cut to precise length. Be sure to add lubricant.
4 years ago
Very interesting design! Got any photos of the actual, physical step stool? If you did, that would be neat to see how it looks in real life.
