A Switch With Makey Makey That Says Who Is at the Door.
Intro: A Switch With Makey Makey That Says Who Is at the Door.
Materials:
4 pieces of cardboard to fold in 1/2
Foil
4 rubber bands
Paper to make labels
1/8" audio cable to run from laptop to speaker in office.
STEP 1: Fold Cardboard in Order to Make a Switch.
I cutout square pieces from a shipping box and folded them in 1/2.
STEP 2: Tape 1 Piece of Foil to the Top & 1 to the Bottom.
After we connect alligator clips to the top & bottom, touching the top & bottom foil will complete the circuit.
STEP 3: Place a Rubber Band Around the Folded Cardboard Toward the Back for Support
This will keep the switch tightly constructed.
STEP 4: Label Each Switch to Your Liking.
STEP 5: Connect Alligator Clips to Your Switches and Makey Makey
Attach 1 alligator clip to 1 side for the command and the other side for the ground. When you press the switches together it will compete the circuit and make the sound. I you don't have enough alligator clips you can use any conductive wire as shown above.
STEP 6: Create Your Sound in Scratch for Each Switch.
Drag 4 "When ____ is pressed" from from events and adjust the ____ to which part of Makey Makey you choose to use.
Drag 4 "Play Sound _____ Until Done" to right under the event.
STEP 7: ​Attach Makey Makey to Laptop (if Not Already Done) and Tape to Wall
STEP 8: Run 1/8" Audio Cable (with Adapter If Needed) to Speaker in Other Room
You can also use bluetooth if the signal will reach as far as you need.
2 Comments
MakeyMakey 3 years ago
Penolopy Bulnick 3 years ago
