A Vertical Wind Generator From Washing Machine Motor
Intro: A Vertical Wind Generator From Washing Machine Motor
Have an old front-load clothes washer and some PVC pipe lying around? Make a vertical wind generator and go GREEN the DIY way.
STEP 1: Remove Motor From Washing Machine
This step was the most destructive using various implements to separate the motor assembly from the washing machine. I'll leave it to your imagination and whatever tools you have on hand. The output of this step should be the coil assembly and the magnet assembly. Keep the shaft and bearings if you can also. Mine were pressed into the washing drum and were difficult to remove without destroying them. Keep the bolts from the coil and magnet assembly also. You may want to use them for your new hub.
STEP 2: Clean the Parts
Clean the magnets and coils, and remove any rust that may have built up on the ends of the coils. Then put a light coat of oil on the metal parts or a light layer of clear coat to keep them from rusting again.
STEP 3: Design a New Hub
This may be the most difficult part. You need to design a hub that will space the coils in line with the magnets, and also have some sturdy bearings at each end. I started out with a block of plastic used for an automotive brake rotor holding fixture. You could make the same on a lathe, or build one up from layers of wood or other plastic, etc.
STEP 4: Shaft Fit
I saved part of the original washing machine drum shaft where the two bearings were located and cut off the rest. Then I added some threaded rod in the end where the original bolt was located. The threaded rod will attach to my blade assembly.
STEP 5: Hub and Coils
Here is the hub bolted to the coils with a cutout for some wiring. At this point, I haven't rewired any of the coils. There are many DIY generator projects on the web using these same washing machine motors and some describe various ways to rewire them for different voltages and currents. Your application will define your wiring.
STEP 6: Finished Generator Assembly
Here's a photo of the magnets and coils mounted on the new hub and shaft assembly. At this point, you can spin the assembly and measure the voltage output, current output, vs. RPM. These measurement steps, and a way to determine the required torque to spin the generator I will save for my next Instructable.
STEP 7: Blade Design and Construction
My blade design is based on some vertical blades I've seen, and in particular, a spinning porch ornament I purchased a few years back. The Idea is to have a cup-like section of the blade always in the direct flow of the wind.
STEP 8: The Blade Design
First mark the cutting lines on the PVC pipe. You can sand off the marks after cutting and/or paint the blades if needed.
STEP 9: Cut Blades
I used a jig saw to cut the long flat cuts.
STEP 10: Cut Blades
I used a hack saw to cut the rounded sections.
STEP 11: Drill Center Hole for Post
I used a hole saw to drill the center holes for the PVC post. The center post has caps on the ends to secure to the threaded rod.
STEP 12: Completed Generator
Here's a photo of the completed generator ready for mounting on a porch, or in a tree, or wherever. This motor was rated at about 400 Watts, so I'm hoping for 50-100 watts in a good wind.
I hope you've enjoyed this Instructable, See you all next time......
STEP 13: Measurements
No load and full load torque was measured using a strain gage load cell mounted on a rod located one foot from the center of the hub. Data was captured using a national instruments DAQ card and DasyLab daq software. No load was all wires open, full load was all wires shorted. I tried to move the rod 90 degrees in 5 seconds at a steady rate manually.
No load torque averaged 0.39 ft-lbs, ful load torque was approx. 1.25 ft-lbs
STEP 14: Measurements
Full load Plot.
STEP 15: Part Numbers
LG Washer model WM0532HW
6501KW2002B
Sears Part Numbers
Stator assembly
PART NUMBER: 4417FA1994G
$97.60
Rotor
PART NUMBER: 4413EA1002B
$63.65
Sensor assy
PART NUMBER: 6501KW2002
Call for availability
(800) 252-1698
Bearing
PART NUMBER: 4280FR4048E
Kenmore 41473
$25.04
6501KW2002B
Sears Part Numbers
Stator assembly
$97.60
Rotor
$63.65
Sensor assy
(800) 252-1698
Bearing
Kenmore 41473
$25.04
116 Comments
wmontigny64 11 months ago
mudita.reddy 9 years ago
OK. I just made this wind turbine using washing machine stator and rotor. When I turn the wind turbine with my electric blower(for testing purposes) I can not even light a small (10 w) bulb. I tried it in 3 phase and 1 phase conection. What am I doing wrong? I hope some one can help with this project I have.
testacorsa 8 years ago
Did you rewire? Check this link:
http://www.thebackshed.com/Windmill/Contents.asp#3
BobDakotanBRJ 2 years ago
Donald steele 4 years ago
3253568 3 years ago
من میخواهم توربین عمودی با لولا درست کنم که وقتیکه پره ها در جهت مخالف باد هستند بسته شوند و در طرف دیگر که باید از باد نیرو بگیرند باز شوند البته لولا باید در انتهای هر تیغه باشد البته یک نمونه ساخته شده در ایران را دیده ام اگر بتوانم ویدئو خواهم گذاشت . لطفا همفکری کنیم
3253568 3 years ago
3253568 3 years ago
I want to make a vertical turbine with a hinge that closes when the blades are in the opposite direction of the wind and opens on the other side, which must be powered by the wind. I can post a video. Please agree
gordonfarey3 3 years ago
apormosa 3 years ago
staytexas 4 years ago
judgeyoung 9 years ago
Very nice yard ornament. Why not build it into a HAWT and put a single PVC blade on it and see if you can actually make some measurable power with it? There is a reason the vertical axis turbines are so inefficient, and a reason that HAWT's have proven themselves better for hundreds of years. Probably not as artistic as your pretty unit, but much more powerful! Let us know if you produce any power.
gmcin5 4 years ago
PauG6 6 years ago
HI\Can you help me
were to buy this shaft the ine you use it
PauG6 6 years ago
I need to buy a hub and a shaft , were can i buy from , please
ajayt7 6 years ago
ajayt7 6 years ago
