Introduction: A Radial Drill Press Made From Spare Parts
My radial drill press cost about the same in materials as small, cheap ones you can buy, and it isn't much bigger or stiffer than those, but it has more freedom of motion than some more expensive machines. It's made from some parts I found and other parts I made. It ended up so the maximum extension is about 73cm - I guess this makes the swing 57" - and the head has about 28cm vertical travel, and it can swivel, rotate, and pivot 360°; it has a 3/8" chuck, the quill travel is up to 8cm, and with the temporary "Hi-Power" gearmotor runs at something like 1000rpm with no load.
Even with more reasonable torque it probably wouldn't make a great everyday drill press, it takes a lot of room and it's difficult adjusting it to drill square, but it's great for drilling series of consistent angled holes in wide pieces of wood. It can drill straight out and even upwards and still is light enough to carry.
Step 1: Parts
The base, column and ram are parts from a power feeder made in Italy that someone got rid of because it has a 550-volt three-phase motor. It came bolted to a 14" tilting top table saw with similar power requirements, but it usually was in my way and anyways one of the wheels was wrecked. It took up even more space when I removed it.
The head is from a hydraulic door closer I found in a pile of them at work. It might have been made by Ilco and it had green wrinkle finish, almost the same color as the feeder but that was something more like hammerite.
The quill is made from a 10.5" long piece of 1 5/8" 1/4" wall 1026 cold roll steel DOM seamless tube I bought from Metal Express, the current price is about $18.
The spindle might be a guide rail from a printer, I found a bunch of them loose in a dumpster, 14, 18 and 20mm diameter, hard outside with different amounts of rusty spots. I think the 30202 and A4050/A4038 tapered roller bearings I bought from a local bearing store were less than $20 each, now they're $25 and $27 from McMaster-Carr. Ball bearings would have been much more appropriate and easier to deal with, and probably cheaper. I used a TCM 20x35x7TC spring loaded double lip seal on the bottom, maybe $7, and just a piece of turned scrap UHMW-PE at the top, held in place with a TN-01 bearing nut, maybe $3.
A little $6 flea market universal motor electric drill drives it, but it would be nice to replace it with a 250 watt variable speed motor. It runs from a 52-tooth XL timing belt with two 15 tooth pullies. I might have got them from SDP/SI, $6 for the belt and $10 each for the pullies. They're a little small.
The feed yoke is a cutoff piece of aluminum bar bent into shape, pinned with pointed 1/4"-28 set screws to a split collar made from steel plate. The handle is a piece of 1/4" rod attached with a 10-32 button head cap screw, and the connecting rod is a piece of brass bar from a player piano exhauster pedal, held on with a couple dowel pins. I modified a 1/2" button head screw to clamp the steel toggle plate to the casting. The feed stop is a piece of leftover 5/16"-18 threaded rod with a couple hex nuts to jam against each other.
Step 2: Headstock
The power feeder used a right angle piece between the motor and the castings so the head could be positioned according to the size and shape of different boards, but in order to rotate in two directions I figured the headstock could just attach directly to the socket at the end of the ram.
I sawed off the part of the door closer casting that had the mounting flange and enclosed the crank mechanism. The bearing assembly for the crank arm was tightly screwed on and firmly seated to the casting with a big, fine thread. The power feeder used bolts to draw tapers together to clamp things in place and all I had to do to combine the two pieces was make a piece threaded for the door closer with a taper to match the power feeder castings on the other end, and tap a hole for a clamping bolt.
Step 3: Spindle
The spindle is a piece of scrap 20mm steel rod. It was very straight and had been ground and plated, it was rusty in spots but I only needed it to be clean a couple places.
My lathe isn't big enough to turn the whole thing between centers so I used a four-jaw chuck and a sensitive indicator to make things as accurate as I could. I probably used a steady rest as well.
The nose is threaded for ordinary drill chucks. I left a clean bit of the original outer surface for the seal in front of the seat for the lower bearing. The upper bearing has a slightly looser fit on the spindle and has a smaller diameter, and it is held in place with the homemade seal and store-bought bearing nut. The smallest diameter is at the end for the pulley.
Step 4: Quill
The bore for the piston of the door closer is round and very straight and smooth, so I bought a piece of round seamless steel tube for the quill. It came very smooth inside, and a little oversize outside. It probably could have a smaller wall with depending on the bearings.
I faced and bored each end separately, using a four jaw chuck and steady rest. I had to remove the leadscrew so I could move the carriage back far enough and it helped that I had installed a carriage rack that's longer than normal. I was going to have the quill ground at a machine shop but I wound up honing it by hand on my wood lathe.
Step 5: Drive
I made a pattern to cast the drive housing in aluminum or zinc alloy but meanwhile I made a crude functional one from scrap Delignit, which is kind of beech plywood used for different piano parts, foundry patterns and bulletproof doors. To get the machine working I just used an old electric drill for power, so it has some non-standard parts but a small treadmill motor will probably work with regular ones.
Step 6: Feed
Step 7: Table
The table is separate from the drill but I made it so I could use them together. It's a torsion box made from plywood and beech scraps; it's 150x80cm with five standard 1/2" t-slots and sets with four homemade plain linear bearings on rails made from Bosch Rexroth extruded aluminum structural rails that I found. A crank at the front turns a pulley wrapped with cable to move the table sideways.
Step 8: Use
It doesn't work much different than a manual pillar drill press - angled holes in wood work best with a bradpoint bit without spurs, and through holes need a sacrificial layer above the table. Handwheels control the height and extension of the head, and angles have to be set by hand. Each adjustment on the drill can be locked in place, including the depth stop which is just a couple jamnuts.
It still needs wipers, it could use a return spring, and vernier protractors for the different pivoting parts would be easy to make and might improve it. The table feed isn't positive, but there's about a meter of cable wound on the pulley to reduce slipping. I might make a vernier for the front, and will probably need to make a brake and way covers for it sometime.
Drilling speed depends entirely on the combination of material, bit size and feed rate, the feedback is kind of helpful but I ordered some surplus permanent magnet treadmill motors that might work better.
13 Comments
7 years ago on Introduction
It is WAY TOO COOL!! Nice ible too!!
12 years ago on Introduction
Wow. what else can I say. Wow. colour me impressed.
12 years ago on Step 8
Wrong size, even if you use Vienna inches
That looks like a good press to convert to cnc. Please have a go, and post the results :)
Reply 12 years ago on Introduction
I need to find a few more parts first!
Haha, your garage looks full of various parts! Isn't there a stepper motor or three?
It's not a garage but full is about right, and the orange thing in the box is one of three slo-syn motors I have. I don't think it would be worth having computer control of more than the table and quill feed even though have to walk around it to make adjustments. The holdup is the quill feed.
I really like this. Recycling...Cool. I just commenting on that you use old standard & metric. It's not confusing to me, but mabye to somebody else. cheers
I figured it would help keep the tolerances straight, but here in central Massachusetts it's also easier and cheaper finding things in (English) inches.
Price estimate?
I think I spent something like $150 on parts as it took shape, a better quality chuck and motor will add at least another $50, and that's ignoring things I didn't use or that I ruined. You might be able to buy just the frame for a power feed, but the modern door closers I saw for sale don't look like they'd work.
if those are all spare parts you have sitting around i'm so jealous of your garage
Awesome! This is insanely insane to all insanity of insaneness to the max of insanity because it is so insane. Nice job!
