AAA Battery Burner Flame 3560 Fahrenheit
Intro: AAA Battery Burner Flame 3560 Fahrenheit
Demonstrating how the AAA battery-powered gas torch works with a flame temperature of up to 3,560 degrees Fahrenheit.
STEP 1:
Drive the battery's positive contact inside to create a bowl. Be careful not to crack the metal or compromise the seal. I use a screwdriver attachment with a blunt end.
STEP 2:
Use a needle for inflating balls as a nozzle. Mark the needle at the side hole and also on the battery.
STEP 3:
Carefully cut around the battery casing with a pipe cutter aligned with the mark.
STEP 4:
Separate the cut part and clean the inside well, removing charcoal residue from the tube.
STEP 5:
Drill a hole in the center of the depression using a tool with a diameter equal to the needle.
STEP 6:
Around the needle hole, make 5-9 more holes within one to two millimeters. I use a sewing needle for this, gently piercing each hole. In a screwdriver, the needle acts like a drill, creating excellent holes in the metal.
STEP 7:
- Cut a piece of copper tubing for air intake.
- Make a hole in the battery casing and weld the tube in place.
- For proper soldering, I use special acid.
- Cut the needle at the point where we made the mark earlier.
STEP 8:
Weld the needle tip to the battery casing. Only weld in a few places, as air should also be drawn through the copper ribs.
STEP 9:
- The torch is ready; you can connect a valve for air supply and regulation. I use an aquarium pump for air supply.
- Connect the needle to the gas torch cylinder with a regulating valve. This is a safe design, as I use the original valve from the store, preventing any unpleasant incidents.
- Adjust the air supply, creating the perfect mixture.
STEP 10:
The torch is safe; it stays cool, and you can adjust the flame at any distance from the nozzle. Thus, the flame from the torch starts from 8 cm with proper adjustment.
