A.B. Mask - for a Nurse by a Nurse
3,066,742
2,415
590
Introduction: A.B. Mask - for a Nurse by a Nurse
About: I am a wife, mama, writer, hobby farmer, crafter, preschool teacher, former trauma/flight nurse currently on sabbatical in urgent care.
***This was designed for love, not profit. Respect health care workers. Please respect my intellectual property. Please don't try to make money off of this - don't be that guy.
A.B. Mask
fabric mask and N95 cover sewing pattern
designed by a nurse for a nurse
I make no claims to the effectiveness of the end product. Nothing homemade will ever compare to medical grade PPE. This is a pattern of last resort. If you have access to the proper PPE use that first - obviously.
Research on the efficacy of fabric masks is conflicting. I have found peer reviewed journal articles reporting homemade cotton masks provide measurable filtration of fine particles (Disaster Med Public Health Preparedness. 2013; 7:413-418). I have also read that fabric masks may increase risks of transmission due to moisture buildup and time of virus life on fabric (BMJ Open 2015;5:e006577. doi: 10.1136/bmjopen-2014-006577). Please inform yourself as best you can.
Many of us front line health care workers are experiencing a range of emotions in the wake of the current pandemic. To add to the confusion and uncertainty, healthcare professionals are being told by hospital administration to use disposable equipment in unprecedented fashion with next to no acknowledgement of the compromised they are making to personal safety. PPE is extremely limited. Nurses across the nation report they are working without access to any type of mask.
In my family, sewing is an act of love. This pattern could be how seamstresses in our communities communicate their solidarity. This mask says, I see you. I worry about your safety and I want to contribute in the way I know how.
Finally, I believe these mask may demonstrate our protest and passive disobedience. We will make a statement when all across the country, medical professionals start showing up to work in fabric masks, sewed by members of their community, from of a hodgepodge of fabrics in every color. The act of wearing this mask could become an visual representation of the sacrifices we are making and our unwavering dedication to care for others in their time of need - regardless of the most recent constraints of the terribly broken system we work within.
Sew On! Be Safe!
love,
Jessica
www.nursemade.co
A.B. Mask This pattern is designed to fit in two ways. First, directly over the face, similar to a surgical mask. Second, the pleats expand, allowing the mask to fit over many models of N-95 to provide a protective barrier, in the hope of extending the lifetime of the respirator. The mask can and should be washed after your shift, just like your scrubs.
I recommend using tightly woven fabric. This pattern was developed using high quality 100% cotton. Pattern listed here is to make one mask out of a fat quarter of fabric. I am confident there are better ways to cut out pieces for large scale production.
Fat quarter of 100% cotton or other tightly woven material - the tighter the better
sewing machine
iron
Step 1: Print the Pattern
Print the pattern. Cut out pattern. Cut along straight black lines and dotted black line.
Choose your fabric - at least 21"x18" (Fat Quarter). Iron out wrinkles.
*I have updated the pattern print out to clarify dimensions of the cutout pattern. I have also included a screen shot of the print settings I used so pattern was true to size. Thank you!
Step 2: Fold Fabric
Fold fabric right-side out with selvage edge touching - taco style. Square fabric.
Step 3: Cut Binding and Ties
Cut 5 x 1.5 inch wide strips from the width of fabric. Each strip should be around 20" in length.The strips above were cut with the fabric folded in half.
Or, if you are cutting out of longer fabric you could cut 2 (1.5" wide x 40" long) and 1 (1.5" wide x 20" long) and save yourself a step piecing the binding together.
Step 4: Refold Fabric and Cut Mask Face
Open up and refold leftover fabric. Fold width-wise - burrito style. So selvage on top, selvage on bottom - fold evenly. Pin pattern on upper half of folded fabric. Dotted line of pattern aligned with fold. Cut around edges of pattern. Cut out notches.
Unpin pattern and move to lower half of folded fabric. Cut out second piece.
Step 5: Stack and Sew
Stack the 2 face mask pieces, face down. Pin in place.
Sew together using 1/2" seam around all four sides.
Step 6: Iron in Pleats
With pointed (top side) pointing away from you, front of fabric side down, bring bottom side of fabric up and over top side. The fold should be the imaginary line between the top notch on left to top notch on right. Press crease with hot iron. The pleats are 1/4 inch.
Next, fold fabric back down. The fold should be imaginary line between 2nd notch on left and 2nd notch on right. Press crease with hot iron.
Repeat for 3rd and 4th notches.
Repeat of 5th (yellow headed pin) and 6th (red headed pin) notches.
(I apologize if this is a little vague. I will work on a video for ironing in pleats.)
Once the pleats are ironed in the edges of the mask should measure 3" - give or take.
Step 7: Sew Pleats in Place
Sew pleats into place using a 1/2" seam. Both Left and Right side of mask face.
Step 8: Mark and Sew Darts
Fold mask face in half at the center fold. Front side of fabric together, wrong side of fabric facing you.
Align pattern and mark top and bottom darts with pin or pencil.
Sew along line. - I went over it twice for good measure.
Step 9: Trim Excess
Trim seams to 1/4 inch.
Now time to bind!
Step 10: Prepare the Binding
Take 2 strips and pin at 90 deg angles. Repeat with 2 more strips.
Sew strips together at 45 deg angle. Trim seams at 1/4 inch and press with iron.
Take 5th strip and cut in half.
Step 11: Attach Side Binding
With mask facing down - front side of fabric facing away, wrong side of fabric facing towards you - pin 1.5" binding you cut in half to left and right side of mask. Binding should be face down. Edge of binding aligned with outermost edge of mask.
Sew in place, starting just above top of mask and stopping just below bottom of mask, using 1/4 inch seam.
Press seam open with iron.
Step 12: Finish Side Binding
Flip mask over. Right side of fabric facing you.
Fold 1/4 inch seam towards you from outside edge of binding. Wrap folded edge around side edge of mask.
Pin in place.
Sew along edge of binding.
Repeat on other side.
Trim excess.
Step 13: Attach Top/Bottom Binding
With mask face, wrong side of fabric facing you, pin 1.5 inch binding strips along top and bottom edges.
Sew in place using 1/4 inch seams. Start sewing just above one side of mask face and end just after opposite side of mask face.
Press open with iron.
Step 14: Finish Top/Bottom Binding and Ties
Trim ties even on both sides of mask.
Iron in 1/4 inch seam on top and bottom of mask ties.
Iron in 1/4 inch seam on end of mask ties.
Fold ties in half and pin in place.
Sew Binding and Ties.
Step 15: Done and Done!
Congratulations!
You're done! You have made a mask that will cover a nurse in need. Now, I challenge you to make another, and then another. Then, get your friends to make some. And once you have a dozen or so, call your local hospital, ask to speak to the Emergency Department, and offer to drop them off (from a safe distance of 6 feet or more). Or offer some to other essential workers!
Thank you, thank you, thank you!
You are amazing. You make a difference.
Wash your hands. Promote social distancing. Keep on sewing.
Love and light from this ER Nurse.
-Jessica, RN
jessica@nursemade.co
ps - publishing a pattern I designed is a first for me. Constructive criticism and edits are appreciated. An updated pattern and video follow along can be found at nursemade.co
146 People Made This Project!
  • Audio Challenge (Share a project that produces sound. October 18)
  • Back to School: Student Design Challenge
  • 3D Printed Student Design Challenge
590 Comments
lindritz
lindritz
1 year ago
Thank you for these detailed instructions. Since your scrubs are washed and dried in hot water and soap (very effective in removing germs) these masks can also be cleaned in the same way. Wash and dry your fabric FIRST in the same way, the cut and sew.
btmtexas1
btmtexas1
Reply 1 year ago
Hey THANK YOU!!! I was getting confused and about to redraw according to the measurements, you saved me a ton of time!
BevM7
BevM7
Reply 1 year ago
When sewing cotton that is going to be washed repeatedly, ALWAYS pre-wash your fabric in the manner it's going to be washed in the future. That way, the fabric won't shrink after being sewn and distort the shape of the finished article.
Learnerleader
Learnerleader
1 year ago
Thank you so much for taking the time to do this while you are working as a nurse. You should pat yourself on the back and take joy in sending this out for so many people to help. It is beneficial during this stressful time to feel like we are doing something to help.
NikkiLD
NikkiLD
2 months ago
I made this pattern for my whole family, some nurses I know and friends. I love the detailed instruction plus I was able to increase the size for my son, dad and brother (they have big heads lol!)
enquery
enquery
1 year ago
Has anyone tried to see if these also work with elastic for over the ears. My nurse daughter says at this time they need to take masks off and on and touching them at the back of the head is not feasable now. (She's not in a Corvid19 ward.)
JWinnebago
JWinnebago
Reply 1 year ago
I just ran out of elastic, I made the rectangular ones with elastic loops behind the head instead of around the ear. People didn't like the 1/4" elastic behind the ear because of the bulk.
I'm going to look for hair ties.
lmnohos
lmnohos
Reply 9 months ago
I took a mask like this & tied the pony tail with big plastic beads so it could slip over my head but then i could flip those plastic beads around to tighten it.
realife11
realife11
9 months ago
Thanks!!! Have been looking for a good, roomy mask diy pattern. This one is perfect and I like how big it is on the face, covering everything (not like those masks that are tailored to the nose and fall down on the face every time the person talks! 🙄).
Thank you-thank you-and thank you!!! 😄👍✌️
woodmsc
woodmsc
Question 1 year ago on Step 15
Some have said the masks need a wire (?) or something inserted for a secure hold on the nose. Do you have any directions for such?
chittah
chittah
Answer 11 months ago
I used the double wire thing from coffee packages and cut the ends so they are rounded. They don't get bunched up like thin twist ties or pipe cleaners.
HaydeeM3
HaydeeM3
Answer 1 year ago
See my photos (I made a pocket for the pipe cleaner to go into for easy removal to wash) Like wise you can sew a twist tie about 8 cm (3 1/4") in length into the bias binding. probably needs to be aluminium so it doesn't rust when being washed. hope this helps.
gitanadeneff
gitanadeneff
1 year ago
Quick question. Just got recruited by my family to make 9 kids masks. Would this pattern work on a child? Should it be shaved down a bit? Or just go rectangle with children masks? Thanks :)
chittah
chittah
Reply 11 months ago
I used it but cut down all the sides of the mask part by about 1 cm. Fits younger children aged 4-8.
xapisgrace
xapisgrace
Reply 1 year ago
I'm wondering the same thing at the moment. My daughter asked for masks for the grandkids this morning.
playafamily
I've been making these to give to my nurse friends. Now I'm making them for friends and family. I've got people who have offered to pay for them. I have them donate fabric to me instead so I can make more to give to people. Thank you for the great pattern too. They fit so much better than the over the ears ones, especially if you wear glasses.
rigamarole23
rigamarole23
1 year ago
I'm so grateful for this pattern! It was actually my first to try back in March; though I've tried at least 4 others, this pattern is by far the most comfortable and stays in place. I modify it a bit with either a continuous loop and toggle closure or adjustable elastic.
Have a question for the group. My Mom has dementia. Though she understands the virus, she's also claustrophobic. Sometimes, even with the AB Mask that stays away from the face, she pulls it down to "get some air." Has anyone tried to add zip ties or boning to this mask? If yes, what did you do? I made Renee McCloud's Zippy Mask but it's just too close to the face compared to the AB Mask. Thanks very much!
usahotair
usahotair
Tip 1 year ago
Hi Jessica! Great work, and thanks for what you do.
I took the liberty of re-drawing your pattern so that anyone can just print the PDF at 100% scale on a 8.5x11" Letter sized sheet. Do not rescale it.
For those without a printer, all dimensions are shown on the pattern and you just need a ruler to draw it out very quickly and easily. Good luck!
Jon in Phoenix, AZ
MamaBeara
MamaBeara
Reply 1 year ago
Can you or has anyone made a child size of this?
