AEG ELECTRIC AIRSOFT GUN ALMOST FROM SCRATCH
Intro: AEG ELECTRIC AIRSOFT GUN ALMOST FROM SCRATCH
Okayyyy i know i have no acuall pics cause my my budget is low but for a fact this works if done right me and my airsoft buddys did this
Now this instructable gives you some leeway as to some parts like gear box and magazine and battery
this will show you how tho make an aeg (airsoft electric gun) ALMOST from scratch
p.s. sorry for spelling
STEP 1: Buying Parts
you can choose to make these but for certant reasons we didnt
you will need(or choose) to buy
-any high capacity airsoft magazine
-AEG semi/fully automatic gear box with motor check "fps" the higher the better
-rechargeable r/c car battery with charger
-barrel could be made with 6mm copper tube
-grip and if chosin for grip
STEP 2: The Gun Body
we made our gun body "UZI" style
you can choose whatever style you like
ours was made of thick platic hot glued together
we also used templates we printed out for the design
build it in halfs so you can screw/glue it together later
p.s. make shure to cut a hole for the magazine and the barrel we forgot and then when we went to test it and had to go back luckaly we used screws instead of glue to keep it together
STEP 3: Inserting Components
now this parts inportant
carefully line the parts so they run smoothly
we glued them to the body but there are other ways to do it
for the magazine lock to keep it in the gun we couldnt figure itt out so rubber bands worked fine
for the battery we hid it in the grip it moves around a bit but i worked fine =/
the barrel should line up great with the gearbox and the magazine and the hole you preveously cut
p.s. dont glue the magazine in or any moving parts in the gear box
STEP 4: Close the Body, Load, Charge and Shoot
last if every thing fit right the body should fit nicely
you then glue or screw(recomended) the body together
if you did this correctly you should be able to easily remove the battery and put it back
same with the magazine
please message me with any ideas, comments, or questions
myspace me www.myspace.com/lpfan621
