APC UPS RS 1000 USB Conversion
Intro: APC UPS RS 1000 USB Conversion
Hi all,
I have just been given an Uninteruptable Power Supply. Great! One drawback, no cables!
It needed:
1 x USB to RJ50 cable
RJ50 cables look like normal ethernet RJ45 cables but have 10 pins not 8.
At least 1 kettle lead with a male connection one end and a female connection the other.
I looked at making a cable, but i would need an RJ50 plug. That wouldn't do! I will replace the socket instead.
It needed:
STEP 1: Popping It Open
I popped it open to see if adding/replacing the data port was a viable option.
STEP 2: Removing the Rear Facia
STEP 3: Cable Layout
STEP 4: No Idea What This Port Is For, But Thr RJ50 Socket at the Bottom in Black
STEP 5: The Board Completely Removed
STEP 6: Underside of Board Where the Socket Is Soldered In
Pinout
SOCKET END
2 4 6 8 10
1 3 5 7 9
BOARD END
APC Pin USB Pin Description 1 1 USB +5V (red wire) 4 shield chassis ground 7 4 USB GND (black wire) 9 2 USB Data- (white wire) 10 3 USB Data+ (green wire)
SOCKET END
2 4 6 8 10
1 3 5 7 9
BOARD END
STEP 7: Adding the Printer USB Socket
http://image.pinout.net/pinout_USB_files/connector_pinout.php?image=usb_typeB_receptacle.gif&pinout=%20printer%20cable
2 1
3 4
1= +5v (Red)
2= D- (White)
3= D+ (Green)
4= GND (Black)
2 1
3 4
1= +5v (Red)
2= D- (White)
3= D+ (Green)
4= GND (Black)
STEP 8: Soldered Wiring
6 Comments
joaquimpestana0 9 months ago
Não encontro no esquema da APC RS 1000
SelfSufficientDan 9 months ago
Naeem Qamar 1 year ago
Mjtrinihobby 7 years ago
Nice work.
deepdvd 7 years ago
Thanks for posting this! I used this to mod my APC Back-UPS XS 1000 instead of buying the proprietary cable. Soldering the USB Type-B receptacle (which I got out of an old card reader) was a pain, but after the third try, I got it to work. I used electrical tape to wrap it to the RJ-50 socket (it appears like that's what you did) and used a Dremel to cut out the opening.
dish39 11 years ago
If interested send me an email on dishthirtynine@yahoo.co.uk
