Introduction: AURDINO DC VOLTMETER 0 to 230/300 VDC MEASUREMENT USING LEAF VOLTSNS300 V1
Here is a useful circuit for Arduino lovers and
experimenters.
It is a simple digital voltmeter, which can measure input dc voltages in 0 to 300V range. The Arduino board can be powered from a standard 9V battery pack, as usual.
As you may well know, Arduino’s analog inputs can be used to measure DC voltage between 0 and 5V (when using the standard 5V analog reference voltage) and this range can be increased by using LEAF VOLTSNS300 V1.
Important Note :: This sensor Needed calibration initially with actual voltmeter.
During first time use. use one voltmeter check voltage and using POT set accurate Value in Arduino serial since value in AC and DC for sensor will be different
LEAFVOLTSNS300 V1
