Introduction: Apparition Apparatus (Halloween Prank)
So I decided to create a Halloween themed prank where a pencil cup mysteriously moves by itself or even flies off of a table next to an unsuspecting co-worker. Muwuahahahahaha!
Step 1: What You'll Need
PN | QTY | DESC |
585442 | 1 | 3.00" Aluminum Channel |
585494 | 1 | 90° Hub Mount Bracket A |
638258 | 1 | 624 RPM Precision Planetary Gear Motor |
555172 | 1 | Planetary Gearmotor Mount A |
625118 | 1 | 4mm to 1/4” Shaft Coupler |
634058 | 1 | 1" Precision D-Shaft |
545548 | 1 | 1/4" Set Screw Hubs |
605118 | 1 | Input Power Board |
545620 | 2 | 1" Bore Tube Clamp D |
632158 | 4 | 1" Diameter Magnets (South) (your mileage may vary.. you may need more or less depending on the thickness of the table/desk you are going through) |
632160 | 4 | 1" Diameter Magnets (North) |
5 | More 1" Diameter Magnets for the bottom of the pencil cup (Polarity does not matter as long as you face them all the same direction) | |
585482 | 1 | Channel Bracket B |
605051 | 1 | SPST Push Button Switch |
1 | MB1040 Ultrasonic Rangefinder + 7 pin right angle header row OR HC-SR04 Distance Transducer Sensor | |
561-KSP2 | 2 | #4 Nylon Spacer (0.125") (for mounting sensor) |
91251A108 | 2 | 4-40x3/8" Socket Head Machine Screws (for mounting the sensor) |
90480A005 | 2 | 4-40 Machine Screw Hex Nuts |
50 | 1 | Arduino Uno |
585008 | 1 | Arduino Channel Snap Mount |
605136 | 1 | Small Solderless Breadboard |
585060 | 1 | Breadboard Snap Mount |
545372 | 1 | 1/8" Hub Spacer (spaces up Breadboard Snap Mount) |
755 | 1 | 1N4001 Diode |
976 | 1 | TIP120 Power Darlington Transistors |
744 | 1 | 1k Ohm resistor |
various jumper wires | ||
ZC.1000.3S.25 | 1 | 3S LiPo battery |
4 | 2 small screws to mount the 90° Hub Mount Bracket to the underside of the tabletop. And one or two small screws to mount the Channel Bracket B (with all the electronics) to the table/workbench as well. | |
2 | depending on how you space your magnets you might neet a couple of small washers between the 90° Hub Mount Bracket and the underside of the tabletop | |
632108 | 8 | 5/16" Socket Head Machine Screw (for mounting the 1" Bore Tube Clamp which hold the magnets) |
632110 | 8 | 3/8" Socket Head Machine Screw (for the hub and motor mounts) |
Tools:
- 7/64” Extra Long Hex Key (57185A44)
- 3/32” Hex Key (7122A16)
- Small phillips screwdriver for the 2mm pan head screws that come with the motor mount
Step 2: The Brawn: Assemble the Magnet Tornado
- Solder the Input Power Board to the motor (optional... makes it easy to connect to the motor with just jumper wires or a JST connector)
- Use a small phillips screwdriver to attach the motor mount to the motor.
- Screw the motor mount to the 90° Hub Mount Bracket
- Put the 1" D-Shaft into the Coupler and then put the coupler onto the motor shaft and tighten both set screws well (tighten the set screws with a 3/32” Hex Key.
- Mount the Hub to the bottom middle of the 3" channel
- Insert the D-Shaft into the Hub and tighten the set screw.
- Mount 4 magnets into one of the 1" tube clamps and 4 in the other.
- CAREFULLY attach the magnet/clamp assemblies into the ends of the channel... make north facing out on one side and south facing out on the other.
SAFETY NOTE:
Each of these magnets has a Gauss Rating of over 13,200! Putting them in groups of 6 makes them SILLY STRONG --- THEY CAN AND WILL MESS UP YOUR DAY IF YOU ARE NOT EXTREMELY CAREFUL.
Also... don't set them next to your phone.
Also trying to assemble anything affected by magnets within a nearby proximity will quickly make you look like you are both drunk and riding a roller coaster will performing the task.... you've been warned!
Step 3: The Brains: Assemble the Ever Watching Eye
I used a MB1040 Ultrasonic Rangefinder because that is what I found lying around... this is about $30 but since we are not doing anything real precise a cheap facsimile should do nicely (for example a HC-SR04).
I soldered a 7 pin male header row to the MB1040 and bent it 90° (though if you are buying new header rows you can buy a pre-bent "right angle" header row.)
Since I am not a huge fan of crimp terminals so I soldered two female jumper wires to my push button and shrink-wrapped it up.
Go ahead and mount the breadboard mount, arduino channel snap mount, button and sensor as shown.
Step 4: The Brains: Wiring It Up
I started with my simple cheap motor controller and hooked up the power to the sensor and the pwm pin on the sensor to pin8 on the arduino. I also added a SPST push button so that I could easily turn the project on and off.
Step 5: The Brains: Programming the Arduino
You'll need the Maxbotix library from https://github.com/Diaoul/arduino-Maxbotix
Step 6: Final Prep
Mounting:
Now Mount the brains and the brawn to the bottom of a workbench or table. I was fortunate enough to have the perfect workbench, with some convenient 2x4s to mount the brains to. Mounting the brains far enough back made it completely hidden to anyone taller than a child.
Prep the Cup:
Put 5 or so magnets on the bottom of the metal pencil cup... make sure they are all facing the same direction.
Testing:
Next do some tests to figure out the best place to set the pencil cup. I marked my favorite spot with a light pencil line.
Step 7: Go Time
Once the trap was tested and armed I set a piece of paper next to pencil cup... I then asked co-workers if they could give me some feedback on a project idea that I had put together.
11 Comments
7 years ago
do you have a video but my tablet just isn't showing me? if not, it would really be nice to see a video of the mechanism in action action action. action. action. Then it would be an action apparition abberation.
Reply 7 years ago
There sure is. Here is the direct link to youtube:
Reply 7 years ago
oops I guess it turned that link into an embedded video.. very clever instructables commenting system, very clever.
You could also try http://controlissues.tv or search for Control Issues in the iTunes music store since we've set up a podcast :)
7 years ago
Did you just "nice" your own pun? :-)
Very good and well executed prank...!
Reply 7 years ago
actually I said "nice" about seamster's pun... then played off it with my own - but the order it is shown makes it look like it happened the other way around :)
7 years ago
This is a fantastic little prank. So cool!
(But did you mean "apparition" though?)
Reply 7 years ago
Apparition means a ghost. So I think it is meant to be like a ghost was throwing/sweeping the cup away from the table.
Reply 7 years ago
Zoiks! Busted. Thanks guys :)
Reply 7 years ago
But hey, "aberration" does work in a sense; seeing a cup move on it's own is definitely an unexpected behavior!
It's an Aberration Apparition! :)
Reply 7 years ago
Aberration Apparition has some good Alliteration
Reply 7 years ago
nice :)
