Introduction: Acorn Necklace
This is how to make a acorn necklace. : )
1 Acorn , wire or a twisty tie , string or ribbon I used ribbon and a clasp or you can tie it i used a clasp.
If the acorn is broken you can super glue it. I had to do that.
Step 1: Step 1 : )
If you are using wire rap it around the acorns stem and make a loop. If you are using a twisty tie take the twisty tie and strip the Outer layer off until there's only the wire and rap it around the acorns stem and make a loop. this is what i did. : ) If you'r acorn is broken us the super glue and super glue it. : )
Step 2: Step 2
take you'r string or ribbon and put it through the loop. I used ribbon. : )
Step 3: Step 3
add the clasp or if you don't have a clasp just tie it. I used a clasp. : )
Step 4: Step 4 : )
you're all done great job. you did so good now go have a good day. : )
2 years ago on Introduction
This is so cute! I love that you can wear nature!!!
