Introduction: Add a LED Flasher/Safety Light to Your Bike Helmet
Add a little safety to you or your child's day-to-day or evening bike ride. The following few steps will outline how to attach a LED flashing safety light to your helmet.
What you’ll need:
1 small screw
1 small drill bit slightly smaller then the screw.
1 drill
1 small screwdriver
1 flashing safety light
Price: About a buck or two at any Target, Walmart, or other retailer.
NOTE: You can often get these flashers FREE at health fairs or fitness/wellness events.
The process is a simple one where you will place a small screw into the clip arm of the light to keep it attached to the back strap of your bike helmet. This makes the biker highly visible since the light is higher and thus, easier to see. I have found this is far superior to placing a light only on the back of the bike frame near the seat post.
Step 1:
Step 1: Check to make sure you have a strap on the back of you or your child’s helmet that will allow you to place the light on it.Slide the light onto the strap and confirm it fits.
Step 2:
Step 2: Remove the safety light from the helmet and drill a small hole near the bottom of the safety light arm.Be careful not to place the hole to close to the edge of the arm to avoid cracking the arm when placing the screw into the arm
Step 3:
Step 3: While drilling the hole into the arm.Be careful not to go beyond the arm and back of safety light.You do not want to drill into the red reflector.
Step 4:
Note: For the purpose of this instructable...I have removed the reflector so you can see the screw does not damage the circuit board that runs the LED light.
Step 5:
Step 4: Place the light back on the helmet strap and use your screwdriver to thread the small screw into the hole in the arm of the light.
Step 6:
That is it. You have completed the process of making you or your child a lot safer for only a buck or two. Enjoy!
12 years ago on Introduction
What did you win ? ;)
