Add a Play/skip Button to Your Standalone CD-ROM Drive
Introduction: Add a Play/skip Button to Your Standalone CD-ROM Drive
If you want to make a CD player from an old CD-ROM drive (view here) but the drive you have doesn't have a PLAY/SKIP button on the front.....Dont dispair, you can add one to most Cd drives,>>>> read on
Step 1: Tools N Stuff
TOOLS:
Soldering iron + solder
PH Screwdriver
Wire cutters
BITS:
CD-Rom Drive (CD Burner wont work, ideally a spare that has no intention of being used again)
PSU
Small wire
push button to use as PLAY/SKIP switch
Step 2: Openning the Drive
**All drives vary in different ways so removing covers could be different.**
before uncliping the faceplate, eject the drive and remove the case so you can see the bottom and front of the drive
on the front of the drive next to the eject button there shoud be a place where a play button would sit (very strange, I know . . .) on mine PLAY was written on the board, there may be more than one spot so play around until you find the right one
Step 3: Soldering
Now, my soldering skills aren't crash hot so i soldered to wires onto the first two contacts, (see blurry pic #1).
***TEST CONTACTS FIRST BEFORE SOLDERING***
I then connected a small reset button of a computer two the wires (see not so blurry pic #2). if your soldering skills are better than mine you may like to attach a similar button directly onto the board.
Step 4: Testing
Now to see if your drive works insert a CD and don your headphones. press PLAY/SKIP button once to start playing. press again to Skip to next track. Press EJECT to stop and press again to eject the disk (kinda like an old tape player, ahhh memories.....)
Your Over sized Diskman is complete!!!
this CD drive has been a great addition to the shed. FYI the car stereo's CD drive IS busted.
Chris Kelly 2008
Be the First to Share
    • Fashion Challenge
      Fashion Challenge
    • Micro:bit Contest
      Micro:bit Contest
    • Lamps and Lighting Contest
    26 Comments
    VilémČ
    VilémČ
    Question 2 years ago on Step 3
    But where i solder the wires????
    BillyR55
    BillyR55
    3 years ago
    is there a way to add an AUX audio in
    Hi kellster_deluxe & readers! Like jerckov, I am also really interested in knowing if it is possible to add a "go back" button. Many years ago I asked this same question on Usenet, but I just got sort of "maybe" or "I think so" answers but nothing specific. Thanks! Carlos Albert
    jerckov
    jerckov
    8 years ago on Introduction
    hi, I know that this is a really old post, but, you know if I can make a "go back" button ? already messed around but didn't found it
    tommah04
    tommah04
    11 years ago on Step 4
    could you do something like this but only with a dvd player?
    djn8o
    djn8o
    Reply 9 years ago on Step 4
    no you couldn't, there is no video out, if the pcb has the spot for a play button you could use the audio output on the back, but you would only be able to play cd's
    ham91185
    ham91185
    10 years ago on Introduction
    this was so helpful that i made one myself :) thanx
    twitsl
    twitsl
    11 years ago on Introduction
    I had a cd reader and a cd burner the cd reader didn't have connections but the writer did.
    Boxcarcrzy12
    Boxcarcrzy12
    12 years ago on Introduction
    Is there anyway to do this, accept to add a headphone jack? Awesome tutorial.
    kellster_deluxe
    kellster_deluxe
    Reply 12 years ago on Introduction
    mmm perhaps, idk, there is a line out on the back of the drive, try mucking around with that (y)
    twocvbloke
    twocvbloke
    Line out to the radio, headphone socket for, well, headphones. easy... :)
    moep
    moep
    Any particular reason I can't use a cd burner? It's an older burner I never want to use again. Will it just plain not work with a burner or were you just worried about people ruining a perfect good one?
    dvdragond2
    dvdragond2
    Hey Im Kind Of new But i actually modded one of my CdRom Drives and it was a burner. so yeah, umm i think that you might need to just keep the psu connected to it, otherwise that burner must have been dodgy
    rac
    rac
    13 years ago on Introduction
    i figured out where the play button 'n my old drive goes by clipping two alligator wires to the solder tabs then connecting the other ends together to see if it worked
    ziptang
    ziptang
    12 years ago on Step 4
    Are you powering the car stereo with the power supply as well?? For if this complete set up worked, take a sheet of plywood and make a juke box out of it!!!
    kellster_deluxe
    kellster_deluxe
    yeah Id love too but atm Im kinda lacking in time, final year in highschool D:
