Adding Bluetooth to a Motorcycle Helmet
Intro: Adding Bluetooth to a Motorcycle Helmet
Riding my motorcycle for long periods of time without any sort or radio got dull quick. I started to wear my bluetooth earpiece inside my helmet, but it was anything but comfortable. So I decided to add bluetooth to my helmet, but helmet kits were expensive going over $100+. Looking around on amazon I found a cheap stereo bluetooth headset for just $25 which I integrated into my helmet. Here's how I did it.
STEP 1: The Headset
The Bluetooth headset I used was the SoundBot SB2200. It cost me $25.
STEP 2: Unscrew the Screws
After unpacking the headset, you're going to want to pull off the ear cushions. Then get your hands on a small flat screwdriver and work those screws off. They're non standard screws, but with a little maneuvering you can get them off no problem.
STEP 3: Pull the Wire Out
Now with the earpieces apart, make note of where the wires go. You're going to unsolder them in order to remove the wire from the plastic neck strap.
STEP 4: Make a Hole
Find a good spot to mount the controls on your helmet. Make a hole large enough to pass the wires through. I don't show it here, but I removed all the cushions from the inside of my helmet to make maneuvering of the wires easier.
STEP 5: Mount It All
You're going to need some spare wire to extend the connection from the speaker to the main board. Also you're going to need to remove the microphone from the main board and mount it somewhere in your helmet. When you've done that, just run the wires to the hole in the side of the helmet and solder them back onto the main board. Use the previous picture for reference if you have to.
STEP 6: Finished Product
Now for the finishing touches. I reattached the plastic pieces to the speakers and hot glued them in place inside my helmet. Then I removed the tape from the controls, placed them in an appropriate position and glued it down and made sure to glue all the way around rim so there were no gaps. Test it out. Mine worked great. It was loud, I sounded clear when i talked through the microphone. All for $25. Saved myself $100!
15 Comments
ryanjblajda 8 years ago
Yeah.....this is good except for the whole drilling through the helmet thing.
teomaragakis 8 years ago
Yeah, it's funny how people don't realize that this destroys the structural integrity of the helmet, making it much more unsafe.
fnunes 8 years ago
jayeshshinai 10 years ago
lvultao 10 years ago
tomfarr56 9 years ago
So, a year latter, how is it holding up? I take it, from the ad on Amazon that these are somewhat water resistant. How about the battery? How is it holding up? It sure looks big in that picture. I don't see how they fit it inside the headset!
lvultao 9 years ago
cwoody08 10 years ago
Does this headset come with two speakers? if so then did you mount the other one on the opposite side in the same fashion, minus the hole? I'm getting the same headset as you, so i'd like to do this the same as how you did it. Thanks!
Alright that's what I figured. Thanks a lot.
abenavente 10 years ago
okay looks nice but if you drill the helmet you loose the strength and in case of crush... your surgery will coast more than a Bluetooth motor pack... i hope you dont crush before you read this
