Introduction: Adorable Wire Cat Earrings DIY
Cat lovers should try this adorable wire wrapped earrings!
Step 1: Materials Needed in Wire Cat Earrings:
2mm Golden Seed Beads
8mm Blue Cat Eye Beads
Silver Copper Wire EPS4.Ocm-0.8mm
Aluminum Wire AW10×1.5cm
0.3mm, 0.5mm Golden Copper Wire
Eye Pins EPS4.0cm
Flat Nose Plier
Side Cutting Plier
Round Nose Plier
Step 2: Make the Shape of Cat’s Face
1st, cut off aluminum wire as the length of about 130mm;
2nd, wrap it to form the shape of cat face as the pictures showed below.
Step 3: Add Eyes and Whisker to Her Face
1st, use the blue cat eye beads to be the eyes of the adorable cat;
2nd, slide a golden seed bead with the silver copper wire to be the nose of it;
3rd, thread three 0.5mm golden copper wire to the “nose” to be its whisker. (Each of the copper wire is 15mm) Then you can see, a cute wire cat is in front of you.
Step 4: Make a Dangle Link
1st, thread beads with an eye pin
2nd, make a loop at the other end of the eye pin as picture shows.
Step 5: Finish the Handmade Cat Jewelry
Tutorial source: http://lc.pandahall.com/articles/2327-handmade-cat-jewelry-idea-how-to-make-adorable-wire-cat-earrings-diy-with-cat-eye-beads.html
