Adventure Time Lumpy Space Princess Plush
Intro: Adventure Time Lumpy Space Princess Plush
Oh My Glob! What time is it? Lumpy Space Princess Plush Making Time!!
STEP 1: Creating the Pattern
Supplies Needed:
Tools:
- Computer
- Printer
- Scissors / Paper Trimmer
Materials:
- Tape
To create the pattern I started out by searching for some images of LSP. I wasn't finding much online that I liked so I ended up taking a few screen shots of her from actual episodes. I used 3 different pictures to create the pattern, one for the body shape, one for the face, and one for the arms. You could also draw this yourself but I wanted it to look like the real thing.
I traced out the shapes in illustrator and sized them so she would be about 17" tall, I wanted her to be pretty big but not giant ; ) After I had the pieces drawn I added a 3/8" seam allowance to the body and the arms.
From here I tiled out the pattern to be printed on 8 1/2" x 11" pieces of paper, there are 9 total and I have included the pattern which you can print and use too : )
The next step is to print out the pattern, and tape all of the pieces together. The pages are marked with registration marks so they are easy to put together. I like to use packing tape to make the pattern more sturdy. I also cut out the slits for the armholes, the finger lines on the hand as well as the gaps between the bottom 3 lumps so I could mark these on my fabric pieces.
Then you just want to cut all of the pattern pieces out and you are ready to start cutting out your fabric pieces!
STEP 2: CUTTING OUT THE PIECES
Supplies Needed:
Tools:
- Scissors
- Weighted object (this helps to hold the pattern in place, I just used a stapler)
Pen/marker to trace the pattern pieces to the fabric (I used a black sharpie, and a metallic pen for the black pieces)
Materials:
- 1/2 yard of purple fabric for the body and arms. I actually used a blanket I found at target, you can find the same one here. This was thicker than the plush fabric they have at Joann's Fabric Store and a nice color too. The twin size measures 66" x 90" which comes out to a little under 3 yards of fabric.
- 1/4 yard of yellow fabric for the star, I used a yellow satin which had glitter too : )
- 1/4 yard of interfacing ( I like Pellon 809 Decor Bond)
- 1 sheet of black felt for the eyes
- 1 sheet of white felt for the teeth
- 1 sheet of light purple felt for the tongue
- 1 sheet of dark purple felt for the mouth
To create your fabric pieces you just need to transfer your pattern pieces onto your fabric. The pattern pieces indicate how many to cut of each and if any need to be flipped over for the opposite side.
For the star, I cut out a 4" x 4" square of the yellow fabric, which was big enough to fit the star pattern piece inside of. Then I cut out a 3 3/4" x 3 3/4" square of interfacing, I always make the interfacing slightly smaller than what I am ironing it to, so the edges don't over extend and get glue on anything. I ironed on the interfacing to the wrong side of the yellow fabric and once attached I cut out my star piece. This was easier than cutting the star shapes first and then trying to match them up, and it also created clean edges once cut.
For the body, I cut the two slits for the arm holes on the front body piece only, you won't need this on the back body piece.I also marked 2 lines in between the bottom three lumps which I used as a guide to define their shape while sewing.
STEP 3: Sew the Face
Supplies Needed:
Tools:
- Sewing Machine
- Scissors
- Pins
- Body Pattern piece (to reference for face placement)
Materials:
- Front Body Piece
- 1 Yellow Star piece
- 2 Black Eye pieces
- 1 Mouth piece
- 1 Tongue piece
- 1 Teeth piece
- Matching thread ( I needed light purple, dark purple, black, white and yellow)
To sew the face I started by attaching the star to the front body piece. I made a fold on my body pattern piece at the bottom of the star and used this as a guide for positioning the star.
Once the star is positioned you can pin it in place and sew it to the body using a straight stitch and sewing as close to the edge as possible. I also added a thick border around the star, since I used a satin fabric I wanted to make sure that the edges didn't fray. I created this finish by using a zig zag stitch on my sewing machine and using the lowest stitch length available. To make the stitching even tighter I just pulled on my fabric as I was sewing it to give it some resistance and the stitches came out really tight and created a thick border. You could also use an embroidery machine for this but I don't have one......yet : )
Next I added the mouth, I created another fold on my body pattern piece at the bottom of the mouth and used this as a reference for placement. Then I pinned that in place and sewed it to the body using a straight stitch and sewing as close to the edge as possible.
Once the mouth piece is in place you can add the teeth and the tongue.I just eyeballed their positioning since the pieces should line up with the edges of the mouth. Pin them in place and sew them to the mouth using matching thread and a straight stitch, sewing as close to the edge as possible.
To finish the face you just need to add the eyes, I created another fold on the body pattern at the bottom of the eyes and used this as a guide for placement. Pin the eyes in place and sew them to the body using a straight stitch and sewing as close to the edge as possible.
Notes On The Face:
For the felt pieces you do not need to do any extra finishing to the edges since felt does not fray they do not need any finishing. Although you definitely can if you like the way it looks : )
STEP 4: Sew the Arms
Supplies Needed:
Tools:
- Sewing Machine
- Scissors
- Pins
- Tailors Chalk (to mark finger stitching)
Arm Pattern piece (to reference for face placement)
Materials:
- 4 Arm Pieces
- Purple Thread
To create the arms take the front and back of either the left or right arm and pin them with the right sides together, leaving the armhole open.
Sew them together using a 3/8" seam allowance. I also added a zig zag stitch around the seam allowance for extra protection.
Remove the pins and turn the arm right side out.
Add the finger stitching lines to the hand, I used my arm pattern as a reference for the finger stitching and marked the lines using tailors chalk since this was on the correct side of the fabric.
Sew the finger lines using a straight stitch, It is a little hard to see this in the pictures but it gives the hands some more character and shows up more when you add the stuffing.
Repeat these steps for the opposite arm.
STEP 5: Sew the Front & Back Body
Supplies Needed:
Tools:
- Sewing Machine
- Scissors
- Pins
Materials:
- Front and Back Body Pieces
- Purple Thread
Pin the front and back body pieces with the right sides together, leave a gap big enough to turn the plush right side out. I positioned mine on the bottom right lump.
Sew the pieces together using a 3/8" seam allowance making sure to leave the gap open. For the 3 small lumps at the bottom I sewed the seam allowance up to a point where I had drawn on lines as a guide, this helped to define their shape. I also added a zig zag stitch to the seam allowance for extra protection.
Turn the body right side out.
STEP 6: Add the Stuffing
Supplies Needed:
Tools:
- Needle
- Skewer
- Scissors
Materials:
- 32 oz bag of stuffing ( you will some left over but a 12 oz bag will not be enough)
- Purple Thread
Add the stuffing. I started by filling in the fingers on the arms, this is a tight squeeze so I used the skewer that came in my bag of stuffing.
Continue adding stuffing until you get your desired lumpiness : ) If want the arms to be able to move around freely, just leave a little gap around the armhole, this way they won't stick straight out like Frankenstein.
To finish of the LSP plush you just need to hand sew the stuffing gap closed. When I was about 3/4 of the way finished sewing the gap closed, I added the rest of the stuffing for this last lump and once it was filled I sewed the gap closed.
And your done!
STEP 7: Enjoy!
Mathmatical! Now you have your very own Lumpy Space Princess Plush : )
22 Comments
melissa.nielson.94 3 years ago
samanthac89 7 years ago
Thank you for the pattern! This is brilliant!
candilover1 8 years ago
snazzy!
CarlyAlberich 9 years ago
hello, I really love it! but I have a problem :( I can't see how I have to sew the arm holes to the body, can you explain it to me please?
Thank you!
mactothefuture 9 years ago
Thanks CarlyAlberich!! Lets see if I can help!! Step #4 is about how to sew on the arms just in case you missed that.
The body pattern piece is marked showing where to cut the slits that are the armholes, make sure to just cut this on the front side (the back won't have any arms)
Next you want to create the arms. Sew two arm pieces together (fron't and back) with the right sides together, and sew the edges but leave the top of the armhole open. Repeat for the opposite arm.
Then to attach the arm just insert the arm through the slit in the body and sew the seams together from the inside so you don't see any stitching.
Hope that helps, let me know if you have any other questions!
Good luck with your Lumps!! Make sure to post a pic when your all done, I'd love to see! : )
ShelbyShifflet 9 years ago
This is amazing! LSP is my all-time favorite character from not only Adventure Time, but from any show out there. I have wanted to make a plush of her for so long and when I found this one, I was so thrilled! I just have a few questions:
1. What was the estimated cost for all the fabric?
2. What foot did you use on the sewing machine?
3. If I wanted to make this plush bigger, how could I do that without messing the pattern up?
And I just wanted to say thank you for posting this(: It is so detailed even beginners can understand! I just have those few picky questions because I REALLY don't want to mess her up(:
Thank you so much ShelbyShiflet! LSP rocks!! lol : ) (one my favorites too!)
1. All of the fabric cost about $25, but I spent $20 on a blanket to use as her main body fabric so you could definitely spend less by getting fabric at the fabric store. The felt is really inexpensive, I think you can get a sheet for about 50 cents!
2. I just used the standard presser foot that came with my sewing machine for all of the sewing.
3. The only thing to note when enlarging the pattern would be the seam allowance since that will be getting bigger if you blow up the pattern. If you are interested I can send you the illustrator file so you can enlarge it easier, you would just need to re-tile the pattern so you can print it out.
Hope that helps! So glad to hear you enjoyed this project! Let me know if you have any other questions! : )
Carleyy 9 years ago
LSP is my favorite!
Mine too!! Lumps!! : )
loompiggytutorials 9 years ago
gravityisweak 9 years ago
Thanks so much!! I just might end up doing more! : )
kgirl5523 9 years ago
Haha! : )
MsSweetSatisfaction 9 years ago
It's so CUTE! Awesome job with the pattern!
Thanks! I was excited when it worked out! : )
EmiClarice 9 years ago
Oh my glob, I'm so glad you liked it! : )
HollyMann 9 years ago
so cute!
Thanks! : )
