Aerodynamics Effect on Distant Experiment
Intro: Aerodynamics Effect on Distant Experiment
Does aerodynamics affect the distant traveled by an object. Here's a SIMPLE EXPERIMENT to solve this problem.
Aim: Does aerodynamics affect the distant traveled by an object.
Manipulated Variable: Paper plane used.
Constant Variable: Starting point and strength used to fly each plane.
Responding Variable: Which plane traveled further.
My hypothesis is that aerodynamics help an object travel further.
STEP 1: How to Begin?
You need to make 2 paper planes. There's tons of videos on the Internet to making paper planes. The first plane (mine was the green one) should be aerodynamically perfect. All the factors : lift, drag and weight should be there. The second plane (mine was the red one) should be more random and less aerodynamic.
STEP 2: Get Started.
Choose your position and throw each plane after with equal strength.
STEP 3: Observations
Take down the observations. I found out that the aerodynamic, green one had a smooth flight, landed smoothly and traveled a greater distance. The red, less aerodynamic plane had a rough flight and it flunked mid air and it wasn't really progressive.
STEP 4: Conclusion
Inference : The more aerodynamic an object, the further it travels.
Conclusion : An object travels further when more aerodynamics is present.
My hypothesis that aerodynamics help an object travel further was proven correct. Yay.
