Introduction: Agility Ladder (free and Easy)
- Duct Tape: You will need 30 feet of it.
- Paint Stirring Sticks: You will need 11 of them. Get the big ones, which are just over 20 inches long. Go to the paint counter at Home Depot: they will give them to you for free.
Step 1: Lay Out the Duct Tape
A standard agility ladder is 15 feet long and 20 inches wide.
Place two strips of duct-tape on the ground, sticky-side up. Each strip should be 15 feet long and spaced one paint-stick apart (center to center). You can stick the ends of the tape to the ground to hold them in place.
Step 2: Lay Out the Paint Sticks
Start at one end and lay your paint sticks down on the duct tape. The ends of the paint sticks should touch at about the middle of the tape.
Spacing is 18 inches. That is, a paint stick at 0", 18", 36", 54", 72", 90", 108", 126", 144", 162", and 180".
Step 3: Fold Over the Tape Edges
Fold over the tape edges. You may have to shift the paint-sticks slightly to get the tape edges to match up.
And... you're done! You can fold up the ladder to take it with you, then lay it out on the pavement or grass to do your drills. Here are a few links that have drills to try:
http://www.kingsportstraining.com/blogs/training-blog/7694405-13-speed-and-agility-ladder-drills-for-faster-footwork
http://www.power-systems.com/n-62-agility-ladder-exercises-drills-.aspx
http://footballgc.com.au/uploads/files/Tony_Raynolds_The_Ultimate_Agility_Ladder_Guide.pdf
Instructables Outdoor Projects Contest
10 Comments
7 months ago
So simple but yet so helpful! Awesome
1 year ago
Good idea to lose weight, let's do it!
5 years ago
I will be doing this tonight.
Thanks
Reply 5 years ago
Cool, good luck!
6 years ago
Thank you for this... I will use sturdy cardboard instead of stick
6 years ago
Thank you so much! It was quick and easy, not to mention GENIUS! Way cheeper than buying one! thanks!
Reply 6 years ago
no problem, glad it worked out for you!
7 years ago on Introduction
I love it! I haven't made it yet but I will. I really needed a ladder.
Sweet!
