Air Blower 2.0 Using PAPER
Intro: Air Blower 2.0 Using PAPER
Welcome friends, today I will let you know how I made an air blower using paper.
You may think it is impossible to do. Let's see it.
If you don't understand my instructions in the following steps, see the video in step 6 and then read the other steps.
STEP 1: Diagram
This is the line diagram of the blower we are going to make.
STEP 2: Cut the Paper
For the impellar I cut the paper into 72 mm x 72 mm square pieces ( about 14 pieces I used, It depends upon the thickness of paper)
For the casing I used 20 square paper pieces of 110 mm x 110 mm
STEP 3: GLUE the Pieces of Paper
take 10 pieces of paper which has been cut for casing and glue them together. if the paper is going to roll slightly iron it using an iron box.
Take 7 pieces of paper which has been cut for impellar and glue them together.
STEP 4: Make the Impellar and Casing
Draw the layout of the volute casing and impeller in the respective pieces as per the diagram in step 2.
Cut the impeller and casing using a scissor or using a laser cutter if you have one.
STEP 5: Make the Vanes
Draw lines in a paper with a gap of 20 mm. We need 8 pieces of paper as shown in the images.
After cutting draw lines with a gap of 24 mm. ( you can also draw it before cutting)
Fold it on the lines. Unfold it and apply glue. Refold it
Now we have 8 vanes.
after the glue dried we need to chamfer one edge of the vane as shown in the image, you can do it by scissor.
STEP 6: Assemble All the Parts
if you want to familiarize with the assembling process beforehand, see the video
Glue the impeller vane and the disk as per diagram
Now glue the DVD holder and the impeller together
Glue the motor and one piece of casing.
fit the impeller to the motor.
cut another piece of paper to wrap the casing disks.
Glue it.
It's time to check it, yes it is working.
THANK YOU.
If you have any doubt, let me know in the comments box.
