Introduction: Airplane Nav Lights Using 555 Timer IC
In this project, we are going to make a very simple RC Airplane Nav Lights Circuit using 555 timer IC, to control 5mm LEDs. The ICs are used to switch the LEDs on and off to create a strobe light effect like Airplane Navigation lights. These can be used in Model Airplanes and give them a very stunning look.
The components used for this project are very cheap and easily available.
For this project, You will need
- 2x 555 timer IC
- 2x Resistors (1 MΩ)
- Green LED
- White LED
- Red LED (optional, can be used in place of white or green LED)
- Capacitors (350nF and 100nF)
- Bread Board
- Jumper Wires
- 12V Power Supply or Battery
Step 1: The Circuit Diagram
Here is the circuit diagram of the project. You will need this to do all the connections.
Step 2: Insert IC Into Breadboard
Take a breadboard and insert the 555 timer IC as shown.
Step 3: Making Connections
Using jumper wires, do wiring according to the circuit diagram.
Step 4: Insert Resistor
Insert the 1 megaohm resistor between the pins 2 and 3 of the IC, as shown in the circuit diagram.
Step 5: Insert Capacitor
Insert one of the capacitor between pins 2 and 1(GND) of the IC.
Step 6: Insert 2nd IC
Now take another 555 IC and make the same circuit alongside the previous one. These two ICs will then be connected via jumper wires to make a strobe light effect.
Step 7: Insert LEDs
Now, insert the two LEDs between the Pins 3 of both of the ICs. We just need to use the PIN 3 of both ICs to connect two LEDs in opposite polarity. This enables only one LED to be ON at a time and thus creates a switching effect.
Step 8: The Power Supply
Here I am using a 5V power supply for the circuit, but you can also use a battery to power it. NO problem at all.
Step 9: Give Power
Now supply power to the circuit. The LEDs should light up.
Step 10: Lights Are Ready
The circuit is ready. Enjoy the lights! Next steps? Install the LEDs in a Model Airplane or a Radio Control Plane to give them a visually appealing look.
