Airsoft Machine Gun Sniper Rifle DIY PVC Blowgun
30,620
337
29
Introduction: Airsoft Machine Gun Sniper Rifle DIY PVC Blowgun
About: A community of family fun, DIY, How-to videos, and Homemade creativity. We hope you can get inspired to make new projects, and possibly learn a little along the way.
In this video, I will show you how to make this awesome airsoft gun powered by your lungs.
It has quick change clips for fast reloading, And for its simplicity, it is quite powerful.
It looks like a sniper rifle, and it shoots like a machine gun.
[Watch Video]
I first started with a previous project, my PVC Marshmallow Sniper Rifle. This is a fun toy to have and fairly easy to assemble.
I first pulled the connections apart where the blow pipe attaches to the T-connector. The T-connector is now getting replaced with a 4-way connector. This will allow our reloading clips to connect quickly. I will show how to make those in a moment.
Before putting the 4-way in place, I first had to roll up some paper and wedge it in the pipe at the front of the stock. This is to prevent any pellets from rolling backwards into the stock.
I next measured the length from the front edge of the blow pipe to the end of the barrel. This is about 17 inches
To make this gun work with airsoft pellets, I needed a much smaller tube inside of the PVC. The simplest way is to use a 5/16 inch metal brake line. These can be picked up at your local auto parts store for a few dollars.
The 17 inch measurement would make the brake line even with the end of the PVC but I will be adding a coupling to the end of the barrel so I used a small pipe cutter to trim the brake line to 18 inches.
The brake line needs to be centered in the PVC, so I wrapped it with some paper at the inlet side which will center it and prevent pellets from finding there way down the side of the barrel. I then carefully wedged the brake line in place from the back. The front of the barrel also needs to be centered by wrapping and wedging some paper between it and the PVC.
I thought about using some glue or expanding foam to hold the brake line in place inside the PVC, but that would make it much harder to clean or repair in the future. I love the option for disassembly so I kept it simple.
I then added the coupling on the end of the barrel for that added flare. If you wish, the coupling can be drilled along its sides for an even meaner appearance.
I then reassembled the gun with the 4-way. With this added connection, I wanted to utilize some quick change clips for fast reloading while in battle.
The pocket-sized clips are very simple and can each hold around 150 pellets. For each clip you will need 2 end caps, a 45 degree elbow, a 4-inch pipe, and a 1.5 inch pipe.
I do recommend gluing the all of the connections on the clips except for the pipe that connects to the gun. This will prevent the connections from separating and causing a loss of pellets and time while on the field.
To load a clip, have the shorter pipe facing up and remove the end cap. Then carefully slide it into the 4-way connector and twist it upward. The pellets will slide down the tube into the chamber and are ready to be fired. Now just give a long hard blow into the mouth piece and a stream of pellets will fly out of the barrel.
If the pellets appear to jam inside of the clip or chamber, a quick hard shake should dislodge any jams and allow for continued firing.
Now you can paint your gun any color you would like.
This is an awesome and yet simple way to impress your friends in your backyard and on the airsoft field.
If you enjoyed this project, click the LIKE button and give us a comment telling us your thoughts.
We try to put out a video every week, so remember to subscribe so you won’t miss out on future projects.
Have fun and be safe playing.
3 People Made This Project!
  • Big and Small Contest
  • For the Home Contest
  • Game Design: Student Design Challenge
29 Comments
docman100
docman100
4 years ago
It’s simple, it’s cheap, it’s powerful, it’s cool, it’s easy, it’s fun, this is a genius invention I can consider it a great airsoft gun it’s amazing, and I’m gonna make it.
Danger_Dolan
Danger_Dolan
5 years ago
is the scope functional?
BLOKRL
BLOKRL
6 years ago
so sad that i dont have PVC
Danger_Dolan
Danger_Dolan
Reply 5 years ago
you can buy it at lowes or home depot for really cheap. like for 1/2 inch, (which i am assuming is what he uses i really did not read through the entire thing just watched the video) is like 2 dollars USD for like 10 feet of that crap. really cheap and easy to get if you know where to go.
wellk0497
wellk0497
6 years ago
Is there instructions?
CalebGreer
CalebGreer
6 years ago
What's the range? Looks fun, but some people take Airsoft REALLY seriously. Can this compete with full sized AEGs and Gas guns?
ejmereen
ejmereen
6 years ago
Will this work with Marshmallows if you do just the extra feeder tube?
SpecificLove
SpecificLove
Reply 6 years ago
The marshmallows would just get stuck in the feeder tube. If you take out the brakeline, you can feed a marshmallow one at a time.
Ajax101
Ajax101
7 years ago
Thank you for showing me this i am always into crafts and stuff like this please share more
Blowgun master
Blowgun master
7 years ago
does this work for regular blowguns? I mean, the clip?
SpecificLove
SpecificLove
Reply 7 years ago
I doubt it
Turtle boy1217
Turtle boy1217
7 years ago
How much will all the materials cost
trapshooter4god
trapshooter4god
7 years ago
is it worthy of a battle
SpecificLove
SpecificLove
Reply 7 years ago
If you are playing with friends, then yes. If you are in a tournament, then maybe not. It really depends on your uses.
trapshooter4god
trapshooter4god
Reply 7 years ago
Ok all I really do is play with friends in my back woods
SpecificLove
SpecificLove
7 years ago
It really depends on how hard you can blow.
starwarsgeek1
starwarsgeek1
7 years ago
looks great definintly trying!!
SpecificLove
SpecificLove
Reply 7 years ago
Have fun
