Alcohol / Can / Penny Stove
299K1.7K68
Intro: Alcohol / Can / Penny Stove
After reading lots of instructables will varying designs of different alcohol stoves made from drinks cans, I made and tested many different designs and noted down benefits from each. This instructable as been put together based on my final design. It is quick to prime, being ready for your pot less than 20 seconds after lighting and will boil aprox 500ml of cold water to a rolling boil in just under 6 minutes using less than 30ml of meths to light and boil with still some life in it if you needed to retain the water boiling for a little longer.
These figures are based on indoor conditions (please use care indoors and ensure you are in a well ventilated area as I was) using my GSI Outdoors 0.6l tin, I have had better results using an old tragia pot with a larger surface area (4:30 for a rolling boil) however this is too large to use when backpacking. Results do vary when used in cold and windy conditions however this gives you an idea of how it performs.
STEP 1: Materials
Ok, so the things you will need are listed below
2x drinks cans
Sand paper (not too course 400grit is about right)
Stanley knife
scissors
Marker pen
Pliers
Book / dvd or something similar to rest marker pen on
Ruler
Paper
Pen/pencil
Drawing pin
Penny
Baked bean tin
STEP 2:
First we want to sand off the paint on the bottom 2inches or so of one can, I found it easier to do this when the can was still sealed with drink in as it was under pressure and less lightly to crumple. We only want to so this on one can however as this will be the outer surface. I used a fairly fine grade of sand paper 400grit as I did not want to damage the surface of the can itself.
Once sanded and you have used the contents :) and rinse out both cans.
STEP 3:
Now you have the cans rinsed out you need to make the pin holes.
Using a drawing pin make one hole in the centre of the bottom of the can you have sanded the paint from.
Now we need to make the pin holes for the burner, I found a total of 21 holes worked best, this works out one hole approximately every cm all the way around. On a piece of paper mark out each cm along the edge and cut this as a strip your can wrap around the can and tape in place. If you cut the piece to 20cm long to leave a gap this will make fixing it to the can easiest.
Wrap the paper template around the can leaving a gap between the ends, the edge of the paper should be positioned 5mm from the edge so your pin holes sit on the side, this allows for a pot to be placed directly on the stove. Start in the gap and make a pin hole in the centre of the gap and work around as shown in the picture.
When testing out other stoves I came across charlieCG's stove his was a great inspiration for some of the features of mine, he has some templates you could try out of you wanted to try different hole combinations.
STEP 4:
We now need to mark out our lines to cut, the base will be the smallest and is made from the can with paint still on, we have left the paint on as this will be the inside can and once used for the first time the paint will heat up and create a good seal with the outside can.
With your marker make a line all the way around the can 1.5cm from the base (total height from the floor not the lip), I was able to place the marker on a DVD and spin the can around to give me the perfect height.
The outer can needs to be marked 3cm from the base I once again used a few items to fix the marker in place and spin the can making a nice clean even line all the way around.
These measurement can vary a few mm if it makes it easier for you.
STEP 5:
With care you now need to cut the cans to size, I found it easiest to rough cut all the way around using a sharp Stanley knife about a cm away from the line and then go in with a pair of scissors and clean up the edges. (if your right handed keep the can on your right hand side this will allow the offcuts to push away from the can without your scissors crumpling the edge of the can)
STEP 6:
We now need to crimp the edge of the base can so it fits inside the top can, with your pliers go around the edge of the can, grip about 5mm of the can in the pliers and twist to pull the edge in, complete this every 5mm or so all the way round.
STEP 7:
Now the tricky bit, to join the cans together push the top can over the crimped edge of the bottom can, it may take a few attempts but be patient.
If you are unable to get them to fit you can get an additional can and push the base of it in to the top can, roll the edge of the can around inside of the top to try and stretch the top out a bit and make it easier to slip over the base.
Push the top down until it completely cover the paint on the bottom can and is nice and even, be careful not to push it too far as its almost impossible to pull back.
STEP 8: Finished
And there you have it, a completed stove, you may want to have a finish up with some more sand paper to get rid of any last bits of paint.
Now the bit I found most important the stand or base, this is simply the top of a baked bean tin cut off to retain the lip, our tin opener fortunately works this way. If your does not and cuts down in to the tin, you may be ale to cut around the base of a tin with a very sharp knife or hack saw and clean the edge up with a file.
I use this base to hold a tiny bit of fuel to prime the stove. Sorry I didn't take any pictures of the stand on its own but I am sure you can get the idea from the image above.
STEP 9: Use
Ok so now as always when dealing with fire care needs to be taken as before you know it you can burn yourself.
I have included a video if how to prime the stove. It is important to put the smallest amount of fuel you can get away with into the base and then swirl it around so it sits in the outer rim. If you have too much fuel in the base it will over heat the stove and cause the fuel to evaporate and burn quicker than you want it to, especially with a tin like I use with a small diameter it just wastes heat.
In the video I only fill the top once for demonstration purposes, trial and error will allow you to find the perfect amount for your application, I fill the top to just under the top 3 times (27ml) to boil 500ml of water to a rolling boil with a little left over just in case (there is nothing worse than running out of fuel just before you reach a boil)
Once you have filled with your desired amount of fuel, cover the top hole with your penny and light the fuel in the base, this will heat the bottom of the stove and allow the fuel inside to start vaporising and that is what you want.
Happy cooking!
Please let me know what you think as I welcome feedback. I have added a guide to what I carry in my kit with my stove so you can see how the full setup compares to the weight of a traditional gas stove.
59 Comments
Heating the top piece to expand it and cooling the bottom piece to shrink it makes assembly much easier. To get a sufficient size difference, heat the top to 400°F (200°C) in an oven (or toaster oven) and cool the bottom piece to 0°F (-18°C, typical home freezer temp). The top will then easily slide over the bottom piece. Use oven mitts!
Just made one this evening and it worked great. The flames were a bit high to start. 5 to 6 inches, 15-20cm. I made the 21 holes as recommended. Suggestions on taming those flames a bit, less holes?
I made one, but I almost burnt my house down! :-(
Yes, this kind of stuff is very dangerous.
It should only be operated outdoors.
Great fun, worked first time and I only had to drink two cans of ginger beer. Forgot to have a penny ready when I lit it but put the centre flame out with a pound coin. Note; pound coins get very hot.
Couldn't find any meths so substituted acetone (my wife's nail varnish remover)
Made the burner jet holes with a small safety pin and bent it onto can before removing it to angle them. Ha, ha... spiral flames.
Looking forward to trying it out doors with meths. Thanks Dan.
Wow, what a cool spiral!
If you don't have methanol, you can use ethanol ( in the form of denatured alcohol or rubbing alcohol)
I live in India, so I have to use rupee coins!
That looks great, I see you went with the angled jets, they look cool!
Great, I made this, but I sometimes have the problems with priming. I light the fuel around the stove, it starts working, but when that outer fuel burns out, the stove stops burning even if there is still enough of fuel inside. My stove is a little higher than yours. Does this happen with your stove and how to fix that problem. I would like to prime it once and that it works after that continually.
If it is too high, there is more distance between the fuel and holes.
This can cause oxygen deprivation, and not let it burn properly.
If you put some cotton as a wick to help the fuel climb up, the stove will work!
So I made this stove, and it blew up the first time I used it! (I'm not meaning to criticize this particular design or article (which was done very well IMO, hence my choice to try it), but I'm just bringing this up for the safety factor about alcohol stoves in general. I made my stove exactly as above, except I made the bottom 3/4" tall (vs 1.5cm) and the top 1.5" tall (instetad of 3cm)... more convenient measurements for us U.S. folk, but still very close to those stated. I used 15ml of 99% Isopropyl alcohol in the stove (All I had around to try it with). I lit it by drizzling several drops of fuel around the outside of the can, about halfway around the can then lighting that. Within about 30 seconds, it seemed to have a steady flame coming out all the burner holes, albeit the flames higher than ideal, maybe 3-4in high. I put a US Army Canteen cup containing about 16 oz (~500ml) water on it, using the canteen cup stand/stove/heat shield designed to slide over the canteen cup for storage, or invert and place under the canteen cup as a base for cooking (mostly designed to cook with solid trioxane fuel cubes or small twigs). I let it burn for about a minute and a half, and noticed the flames had died down significantly from when first set the cup/stand on it-- I pulled the canteen cup off the stand to check if the flames had died, and they had not, and started growing in size again with the increased ventilation, so I set the cup back down on it to heat the water some more. About 15-20 seconds later I would guess, there was a loud boom (my ears were ringing afterwards), the canteen cup flew straight up about 4 ft in the air, the canteen stand/stove base blew apart and flew away about 20ft, and the stove blew into pieces sending aluminum shrapnel up to 20ft away or so.
I collected many pieces of debris. I tried this out on a pleasant spring day, about 70 deg F. or so. Not sure if the canteen stand/stove was small enough that it reflected/held in too much heat, or the type of fuel, or what, that led to this. This was my first try at an alcohol stove, and it will also be my last I think!
I'll stick to commercial stoves from now on I think! My 12 year old son was standing about 5 feet away, and I was about 2ft away watching the stove when it happened, thankfully neither of us got injured!
If you put something inside of the stove like a little wick material,or something like that to hold more fuel,would it make for a longer fire,or would it catch fire inside to stove when it gets low?
There's no oxygen inside the can, so no, it can't catch fire.
can I use kerosene instead of alcohol
Probably not. Kerosene would require a wick (like a tiki torch). This design is burning the fumes.
I made this about 60 years ago when I was a Girl Scout, We used a m]small can such as tuna fish comes in. We rolled up corrugated cardboard that was as tall as the can and placed that in the can. We thin poured melted paraffin over the cardboard. On top of that we would take a coffee can and using an old fashioned can opener made triagular cups arouund the top. Cooked lots of meals on that little stove.
I made those too, but that is a totally different kind of burner.
I've never had one of these that lasted more than a few minutes before starting to deform from the heat. I could put it in the ground or something I guess. What would you recommend?
Hello NumbersAndLetters, living in USA close to the Canadian border we sometimes get beverages which have been canned in Canada. We've noticed the aluminium is thinner on these containers. Thin aluminium could be the culprit.
No offence intended to our Canadian friends! We understand it's wise to be thrifty with materials.
Your can is possibly deforming because it is aluminium, try using a steel can, that should be fine (test it with a magnet to find out).
More Comments
