Alkaline Experiment
Intro: Alkaline Experiment
An alkali also can be defined as a base that dissolves in water. A solution of a soluble base has a pH greater than 7.0. The adjective alkaline is commonly, and alkalescent less often, used in English as a synonym for basic, especially for soluble bases
This is fun experiment of making alkaline solution.
By this experiment you will able to know the acids and bases(alkaline) better.
LET'S GET STARTED
LET'S GET STARTED
STEP 1: Required
This are easily available at home
1.Acid (turmeric,lemon,vinegar,...)
2.Base(dishwashing soap,baking soda,......)
3.Beaker or container
4.Stairer
5.ph paper or litmus paper (optional)
4.Stairer
STEP 2: Mixing Acids and Bases
Add the acids and bases together in a container and stair it well
so now you will get a green, blue, purple, or black kind of solution if you had selected the substances correct.
Note-If your mixture is dry then add some water to it
Now you had turn a acid to an alkali
STEP 3: Here Are Some Examples
PLEASE LIKE IT ???
