Introduction: All of My K'Nex Weapons
this is just a gallery of all of the weapons that I have made out of k'nex, however if you would want me to make an instructable on one of them then just say.
Step 1: Hellstorm 56.4
This is my favourite weapon because I think it looks the best, but I only built it to see how i would put the magazine behind the trigger. the only problem with this gun is the range as it only shoots about 20-30ft, but on the good side the magazine is easily changable and has ten shots
Step 2: Hellstorm 57.8
This is my next favourite gun because it is fully customisable. you can change alot of it, the barrel, the sight, the stock and the mag very quickly. This gun shoots around 40-50ft very accurately with the same mag as the Hellstorm 56.4.
Step 3: Hellstorm 58.2
This is another experimental weapon were this time i have put a safety lock on the gun which is located at the front of the gun. when the safety is off the extra part can be used as a secondary handle. this gun shoots 40-50ft and uses the same mags as the other 2. the sight is reasonably accurate so long as the target is in the centre.
Step 4: Hellstorm 59.9
This was the first of the hellstorm series that i made but i put it last because it's functioning is the worste as the mag cant be changed and the trigger can be abit dodgey. On a possitive note it has a higher rate of fire than the others as it is pump action instead of bolt. the accuracy is good enough to hit a moth at 2 meters away, but the power only goes up to around 30-40ft.
Step 5: The Excalibur
this is my favourite pistol even though there isn't much to say about it. it fires 30-40ft and has reasonable accuracy. it also doesn't require many pieces so it is good for someone just starting out with k'nex
Step 6: H-S 50.3
I wont take credit for this gun becaause it isnt mine, i got it from oompa loompas official sidearm but i did make some changes for example i made the mag shorter yet take more bullets as well as the trigger guard which i just moved abit. this gun shoots around 30-40ft like the other pistol.
Step 7: Flick-knife
this is just a basic flick knife.
Step 8: Curved Knife
this isnt the best knife in the world because it brakes fairly easily and wrecks the green connectors
