Altoids Mini BBQ Pit
Intro: Altoids Mini BBQ Pit
Get your parts together.
1. Altoid can
2. 5 long bolts with two nuts for each bolt.
3.flat head Screw driver
4. Drill bit bit slightly larger that bolts
5 Optional heat resistant paint for BBQ pits.
1. Altoid can
STEP 1: Bending the Hinges
Use the screw driver to bend the hinge.
STEP 2: Separate the Lid and Can Separated
A look at the two halves separated.
STEP 3: Drilling Holes
drill several small holes using a drill bit.
STEP 4: Drilling Leg Holes
there shall be 4 holes slightly smaller than your bolts.
STEP 5: Leg Holes
inside look at the holes.
STEP 6: Preparing Legs
but 4 nuts on your 4 bolts as picture shows.
STEP 7: Putting Legs On
put a nut on the bottom side and the top side.
STEP 8: Install Legs
Ad nut to bolt and adjust down a 1/4 inch.. Push the bolt through the hole and attach the remaining nut. There will now be a nut on each side of the bottom of the mini BBQ.
STEP 9: Putting Together
flip the top and lay it on the bottom half.
STEP 10: Adding Handle
drill another hole to the right so you can lift the top half and feed the fire.
STEP 11: Painting
use a special kind of spray paint that is fire proof.
3 Comments
bobbyflay2019 9 years ago
Can you show a step on how to put a fire in there?
texashippie 10 years ago
