Introduction: Altoids Phone Charger
Step 1: Items You Will Need...
You will need: An altoids mint box, positive and negative wire, USB car charger, electrical tape, wire cutters, small screw driver, Pliers, 9V battery, 9V battery adapter, (optional) and your phone charger.
Step 2: USB Car Charger...
Take apart your USB car charger, unscrew the 2 screws then take out the USB charger itself.
Step 3: Connect Positive and Negative Wires...
Connect positive and negative wires, positive is the spring, negative is one of the 2 bendable parts. The wire I used 22 Gage wire. Cut the wire so the copper/ metal can twist around the positive and negative parts. Electrical tape the wires.
Step 4: Connect to Battery
Connect the positive and negative wires to the battery (make sure the positive and negative wires are on the positive and negative of the battery). To make it easier buy a 9V battery connector to connect the 9V battery to the wire. (As shown in the second picture of this step).
Step 5: Cut Altoids Tin
Cut altoids tin to the size of the USB car charger, use your pliers.
Step 6: Put Everything in Place...
Put everything in place, put in the USB car charger and tape down with the electrical tape. Do not tape 9V battery.
Step 7: Charge Your Phone!
Enjoy and charge your phone! Never need an outlet again!
15 Comments
3 years ago
Based on this other instructable: https://www.instructables.com/id/Duct-Tape-Mini-Flashlight/ I made my own without altoids can
Question 3 years ago
Do you have to use the spring for the positive wire?
Answer 3 years ago
I just tried it without the spring, and the light is turning on.
6 years ago
Any way of making this in a rechargeable version?
Reply 3 years ago
Sure look into lithium rechargable batteries that have a micro USB port directly on the battery. You could cut an additional hole in the side of the tin and then recharge via USB.
4 years ago on Step 3
Where do you get the positive and negative wires?
Question 5 years ago on Step 7
does it really work
Answer 5 years ago
Yes gets my phone to 78% on a good new battery
Answer 5 years ago
Built right yes.
7 years ago
You should use some sort of rechargeable
7 years ago
If you got more money to spend. Get an 8 AA battery holder, switch and a larger project box. The 8AA will last longer and give you more charge.
7 years ago
Cool project, how much juice would one 9v battery give? Will it charge phone fully at least one?
7 years ago
What if the battery dies? Do i replace the battery?
Reply 7 years ago
which is why u should use a a 9V adapter so that you can change it very easily
7 years ago
Cool!
