Altoids Portable Phone Charger Easiest
Intro: Altoids Portable Phone Charger Easiest
I apologize in advanced for working off a completed project, the painting wasn't good, I wasn't using a good spray paint for it.
STEP 1: Items Required
1. Altoids Tin
2. Drill with bit
3. Car Phone Charger
4. 9 Volt Battery Clip
5. 9 Volt battery
6. Hot Glue Gun
7. Spray Paint (optional)
2. Drill with bit
5. 9 Volt battery
6. Hot Glue Gun
STEP 2: Drill the Hole
Drill the Hole for the USB connector...
STEP 3: Strip the Car Charger
Strip the car charger, revealing the circuit.
STEP 4: Glue the Board Into the Tin
Glue the board into the tin, it should fit snug into your hole for the USB.
STEP 5: Solider or Hot Glue
Solder or hot glue the positive lead to the spring, and negative to the outer rings.
STEP 6: Hook It Up and Your Completed
Your done, now charge your phone and check out my other Altoids instructables!!!
Warning: If the 9 volt battery goes too low, a iPhone will give you an indicator saying that charging is not supported with this device
6 Comments
300sqFt 10 years ago
This is great! Do you have any issues with heat as it's charging? -I'd like to do a leather or leather-covered version (gettin' fancy!) but I would worry about heat build up...
bobdabiulder 7 years ago
The car adapters are more efficient. Heat wont be a concern. I'd be more concerned with the 9v battery dying, they have low capacity ):
pichonfrog11 9 years ago
Epowers11cr 7 years ago
gman47 9 years ago
GermanSloth 10 years ago
