Introduction: Altoids TF2 Spytron 3000 in 10 Ridiculously Easy Steps!
So this is my first instructable. I hope you like it! PS: read the instructions before crafting (this is very recommended)
supplies list:
• Altoids tin
• cardboard box
• rubber band
• hot glue gun and glue sticks
• marker or pencil
• patience
• scissors
Step 1: Beginning
To begin we must get a workspace and grab all our materials and tools, then we may begin.
Step 2: Getting and Cutting the Box
Snippy snip time!! Cut one of the top panels (witch ever panel that doesn’t have tape, or a tag, or writing, you only need to cut one piece.
Step 3: Measuring
Put the tin on the panel and write on it with your pencil or marker
Step 4: Cutting the Measured Panel
Cut on the drawn lines and try your best so it can glue easily.
Step 5: Measuring in the Tin
Put the cut panel on the tin and see if it fits.
Step 6: Take Out the Panel and Colour It
Colour it with your pencil or marker (I used a marker) and draw it to match the TF2 spytron 3000.
Step 7: Cram in Your Cut Piece
Cram the other piece into the tin (or glue it, but I crammed it).
Step 8: Glue on the Panel
Plug in the glue gun and glue on the panel on the corners. I recommend putting it on the corners on the inside near the edge or it may not shut properly.
Step 9: Glue on the Rubber Band
Don’t use too much glue or it will break (like mine :.[ Or you could use a different material to make it stick).
Step 10: There You Have It!
Put whatever you want in that rubber band slot (or don’t lol) and paint it if you want.
