Altoids Tin Alcohol Stove
Intro: Altoids Tin Alcohol Stove
I've seen this all over the internet, and decided I would make one myself. There isn't a whole lot of variation that can be done to the design, and this is pretty much a direct copy of the stove design found here: http://www.backpacking.net/makegear/altoids-stove/index.html
This is a cool idea, very cheap to make, and I think it needs more coverage, so here it goes, my first instructable, how to make an Altoids tin camping stove!
STEP 1: What You Need:
Materials:
A mint tin, for this one we're using a rectangular Altoids tin.
A section of fine metal mesh, windowscreen works great.
Some perlite, which is cheap, and easily found at most garden supply stores. I've heard you can substitute fiberglass insulation for the perlite, but I have not tried this and cannot confirm.
Tools:
Some shears or other tools to cut the metal. Heavy-duty scissors should work fine.
A ruler to measure the tin and screen.
A permanent marker to mark your measurements.
Optional:
Some sandpaper to remove the paint from the tin.
Tools:
Optional:
STEP 2: Measuring the Tin and Screen
Before you cut the windowscreen, you need to measure the dimensions of your tin. Obviously, a square tin will be easier to cut for. The Altoids tin we're using happens to measure a little under 9.5 cm x 6 cm, but if you cut the screen at those dimensions it should fit. Mark your measurements with a permanent marker on the windscreen.
STEP 3: Cutting the Screen
Use your metal cutting instrument to cut along the lines you just marked. You will need to trim the corners slightly to fit the rounded corners of the tin. I trimmed the corners 1 cm diagonally. Trim the rest of the screen accordingly to fit.
STEP 4: Filling the Tin
Fill the Altoids tin with perlite, as close to level with the top as you can. Try to get the largest chunks of perlite.
STEP 5: Fitting on the Screen
Now, push the screen on to the stove. Fit the corners under the rolled edges of the tin, and once you get it in it should be in there for good. Once that's in, you're ready to go!
STEP 6: Tips for Use, and How It Works
Use ONLY Denatured Alcohol, 91%. 70% is also available but has too much water and will smoke. You can find the fuel at a hardware store, and an example is pictured below.
Copied from Paul Dryer's site: http://www.backpacking.net/makegear/altoids-stove/index.html
"I use a little plastic spring water bottle as my fuel bottle and find 3 capfuls burns plenty long for most meals. Also for shorter trips, a 4 oz. nose spray bottle with the internal straw removed makes a good fuel bottle. You can squirt fuel (Alcohol Only !!) right into the stove....un-lit, of course! You can even fill the stove to the brim and be ok. To simmer simply cover part of the screen with a bit of aluminum foil. Boil times are about the same as a soda can stove.
Principle of operation: Alcohol 'wicks' up into the perlite for initial lighting. As the perlite/stove heats, alcohol reaches vapor pressure and accelerates through the screen to the flame. Looks like an esbit tab on steroids when burning and if used in an esbit stove, the height is perfect."
Couldn't have said it better myself. Additionally, I've found that keeping the lid attached is a great idea, because you can essentially "turn off" the stove by flipping the lid closed!
WARNING: The flame is INVISIBLE, so be careful! Be safe and enjoy!
86 Comments
YotaTruck 14 years ago
jibbers75 13 years ago
Arbormakes 3 years ago
It will burn your hand, your tool, and if you are pouring straight from the bottle, the whole thing will spontanoisly combust.
TANZMEISTER 13 years ago
Billster36 8 years ago
If you use the ISO-Heet that is isopropyl alcohol. Also better for your car if you use it in your gas tank.
zachary.krawczyk.3 9 years ago
Certain HEET products are isopropanol, but the others are methanol (methyl alcohol). You really don't want to mix up the two if you're working with them
siegeking 9 years ago
no no design will really allow that
Can you tell me how long it burns?
THEJJRAT 8 years ago
Micky Mouse: Yey
Ben_the_Sci_Kid 13 years ago
glorybe 8 years ago
You may have to ask several stores but 90% alcohol in available and it is 180 proof meaning it will burn nicely. A quart might cost $1.50 these days.
A flyin muffin 13 years ago
dolfinmagikpro 12 years ago
glorybe 8 years ago
Cheap Vodka is not so cheap these days and being that 100 proof is only 50% alcohol it is a bummer and unlikely to stay lit or lite easily. Moonshine might reach 190 proof but it is illegal and expensive. best to buy alcohol at Home depot or Lowes in a decent sized container.
glorybe 8 years ago
Try using sand instead of the perlite. It may work for you. It may depend upon the sand used. Larger versions of this have worked with sand. In essence the sand gets warm and the fuel lower down in the sand sends vapors to the surface which ignite. i do not know the depth limit for a sand filled container to function properly.
bwshillington 8 years ago
How would it work to keep the lid and poke a couple rows of holes? Would it essientially become a lightly-pressurized jet stove?
Biopyro 14 years ago
isrlear 14 years ago
