Altoids Tin Candle
Intro: Altoids Tin Candle
A simple instructable to teach u how to make an easy candle for camping or surviving in the wild.
STEP 1: Items Needed
All u need is a glass jar or anything else to melt your wax,four to six tea light candles,an empty Altoids tin,and either super glue or a hot glue gun.
STEP 2: Removing Metal and Wicks From Candles
Remove the metal from the tea lights and also CAREFULLY remove the metal base and wick and save them for later.
STEP 3: Preparing Altoids Tin
Glue down the wicks for the tea lights into the bottom of the Altoids tin. You can either put one in the middle or one on the left and right(i prefer to put two wicks) but in the picture i tried it with only one.
STEP 4: Melting the Wax
to melt the tea lights place them all in a safe,thick canning jar and place the jar in a pot. Fill the pot up with enough water to cover enough of the sides of the jar but not to much that it will go into the jar. Heat the water on your stove gradually until all of the tea lights melt. Once the wax is in liquid form pour it into the Altoids tin and either let it sit out disturbed to harden or place in the freezer to let it harden quicker. And that is all u need to do to make a cool camping or emergency candle.
54 Comments
stinkybob1965 8 years ago
You could also use a Citronella candle for wax. I only camp once or twice a year and we wind up buying citronella pots every year and tossing them after using only a fraction because they get gross with all the dead bugs and debris. Plus you'd have plenty of Citronella wax left over to make them again and store for next year without the smell of Citronella in your house.
Degga_D 9 years ago
nathanya 9 years ago
haha sounds good to me
missie_1999 11 years ago
smiledr 12 years ago
Archemedes54 12 years ago
nathanya 12 years ago
Suzanne in Orting 12 years ago
I was thinking about trying these with the Boy Scouts since I have a bunch of candles that could be recycled.
Thank you,
Suzanne
l_skywalker 12 years ago
Korndog 12 years ago
apretzel 12 years ago
frogmama 12 years ago
I wonder if the pan ideas people are suggesting would work. Hopefully it wouldn't warp the tin. Might be worth trying if you are just making one or two.
Avatar_I_Am 12 years ago
Remember that the more wicks you use, the brighter the output, and the more heat you end up with on a cold day.
Larger tin, more wicks... big enough and you can heat water over it.
If you use the mini Altoids can with one wick, you get a 'Warning Light' you can put out around corners of stairwells, etc., so you can see the Zombies coming...
I have made them in candy tins, up to 5"x3"x1", with 10 wicks. And with the silver lid at 90 degrees it produces anopugh light to read by for over an hour, and, with the lid folded completely down, enough heat to warm your tea.
Fun stuff, Zombie Candles!
With the Mini Altoids tin and one wick, if you are camping replace 'Zombie' with 'critter', and if you add juice from a lemon or orange peel, it helps keep away bugs, too.
