How to Make an Ammo Can Stove
Intro: How to Make an Ammo Can Stove
East to carry, setup and use.
STEP 1: Packed Up
The ammo-can in its travel mode currently carries my 1 liter Billy-Can (inside the Billy-Can, I carry tea bags, sugar, fire making kit, Montreal steak spice, a can of milk) two cups, the skewers and hotdogs
STEP 2: Construction
I started by drilled ten 1/2" diameter holes along both sides 1" above the bottom of the can and a 2" diameter hole in one end (to feed in the fuel) and ten 3/16" diameter holes along the top to put the skewers through (they would form the grill).
I use six stainless steel skewers cut to 1" longer than the width of the ammo-can and with the ten holes across the top I am able to make the grill as wide or as narrow as I need. Also they can be used as skewers to cook a shish-kabob if so desired.
STEP 3: Getting the Fire Going
Because of the shape of the ammo-can (the heat is always redirected inward and up) and the small diameter of the fuel (tI usually use dead twigs and small branched, nothing bigger than the diameter of my thumb and a little birch bark to get it going) the fire burns hot, fast and clean and there is very little ash left and after the fire is finished the ammo-can cools down very quickly, so cleaning up and packing up is fast.
STEP 4: Cooking
The ammo-can stove will boil 1 liter of water in 3 to 5 minutes depending on the type of fuel that is used,
With the ammo-can stove perched on a couple of flat rocks there is no scorching of the earth below and because the fire is contained in the steel ammo-can it works well in wet or snow covered ground conditions. DO NOT USE INDOORS!
50 Comments
ugliknife 1 year ago
Mick Bevan 5 years ago
Hi there....what did you do to the hinge pin of the lid? Did you cut it off entirely?
bjcomp2384 4 years ago
Makerneer 5 years ago
XMAN049 7 years ago
Great idea! Simple but effective.
darthbindy 9 years ago
Fantastic idea! I'd been wanting to build one that would fold to save space, but this would double as a container, while probably being more sturdy than anything else... Love it.
scuddzy 10 years ago
silveravnt 11 years ago
cody27 12 years ago
thanks for the great idea, think ill have to make on of these.
Ricardo Furioso 12 years ago
You've not only found a great way to reuse something, you've given a lot of other people inspiration to take what you've done and expand and improve upon your ideas.
Thank you.
Stanislaw 12 years ago
sgt jacob j. 13 years ago
Callum Snowden 12 years ago
sockless 12 years ago
Sounds like a great way to gas yourself. If the soot etc doesn't kill you, the carbon monoxide will. That's also why you shouldn't use gas cookers inside without proper ventilation, and just never inside a tent unless you want to have a burnt down tent, with you inside.
nazo13 13 years ago
The Ideanator 13 years ago
Schpool 13 years ago
th3_v1k1ng 13 years ago
I also intend to get some threaded bar.. drill a hole in each corner and use 4x25cm bar as legs.. these legs can be pushed into the ground to stop it from falling over.. or overbalancing.
I tested the stove with a kettle on 1 side and found it a bit unstable.. I wanted to boil the kettle and have a pan on the other side with say soup in it... and have a brew and meal at the same time.
I'll pop some pics up as soon as I've finished.
Changed my mind slightly about the bar and used 4 big bolts. Welded a nut on each corner to screw the bolts into.. which means they are slighly adjustable to make the top level to cook on.
http://www.thebookonline.org.uk/images/10112010606.jpg
Is a pic of the stove..
Great idea, going to be take this to a LOT of bike rallys and events, when I;m camping with the dog. Thank you Donkycat for the idea.
louisecross 13 years ago
