Android Security Cameras
Intro: Android Security Cameras
It's common to have a couple of old or outdated android phones lying about collecting dustThen it occurred to me, why not turn it into a local wireless surveillance camera? I decided to do just that. Basically, what I am about to show you is how to turn an old android phone with a camera into a local wireless surveillance camera so you can spy on people in your house.
STEP 1: Step 1
First off, you.'ll need some form of android phone with a camera, and some other device capable of using the internet e.g. laptop, pc, tablet, another phone etc.
1. Download an app called IP Webcam from the play store. This use your phone to broadcast video over your home network. #
2. Once this is done, open the app and scroll down the list until you come to the bottom and see the 'start server' button. Click that.
3. Conceal the phone somewhere discreet. Make sure the camera has a good view of the room you want to spy on. You might want to plug it in, as it may lose power quickly.
4. Make note of the IP address and port number at the bottom of your screen.
STEP 2: Step 2
On your camera-viewing device e.g. your laptop or in my case tablet, you can either just go to your web browser and type the IP address and port e.g. http://xxx.xxx.x.x.x:xxxx (just an example). This works fine, however, you might want to consider using another app below (if you have a tablet or phone to view the cameras on).
1. Download an app called 'tinyCam Monitor Free'.
2. Run it and click no when it asks if you want to automatically add random cameras.
3. Click the + button or add a camera (under the manage cameras menu).
4. Scroll down the list. When it says 'Camera vendor', change the default to 'IP webcam for android'.
5. Just underneath that, put in your IP and port number from step 2.
6. Back out of the menu until you get to the home screen of the app and press 'Live View'.
7, If you followed the steps correctly, you should see a screen with a view of your kitchen or wherever you chose to put your camera.
Note: If you want your camera to see in the dark, get some infared LED's. Look it up.
Note 2: Notice how you can have up to 4 cameras connected at any one time... More uses for old android phones!
Note 3: Hours of fun to be had pointing your camera at your viewing screen :D
Have fun spying! ;D
Have fun spying! ;D
STEP 3: Troubleshooting
1. The most common error is to forget to change the camera vendor to 'IP webcam for android'. Make sure you have done that. To see how, look again at step 2.
2. Are both your devices connected to the internet?
3. Does your camera have anything blocking its view?
4. Have you put in the IP address correctly?
5. Have you put in the correct server port?
6. Have you tried turning it off and on again;)
16 Comments
stern2894 4 years ago
kedwa30 7 years ago
Great instructible! Thanks! But I also have several old phones that are not android. Can anyone refer me to instructions on how to use the cameras from an old phone? I can take it apart if necessary. I want to re-use these old phones in part to learn about electronics, so it is worth my time to try. Thanks!
James116 7 years ago
IP Webcam is great and works like a charm but here are some other alternatives that you can try out: http://www.360-tech.com/turn-android-smartphone-security-camera/
duncangallimore 8 years ago
I tried this with an old Sony Experia Go. It just keeps crashing - is the spec not good enough?
Thanks, Duncan
bpujals 8 years ago
do you download this app on both phones?
CraigH4 9 years ago
I love this and set mine up today using an old S3 Mini I had and works great. One question though, when you say If you want your camera to see in the dark, get some infared LED's. Look it up. what exactly do you mean? I've had a look but don't really know what I'd need to get and what to do? Any help greatly appreciated.
Cheers
ChadM1 9 years ago
@CraigH4 Infared is a wavelength of light that is invisible to the human eye. Using infared filters cameras can see the infared light. IR is a very common practice for security cameras because i provides enough light to identify subjects and remain discreet at the same time.
I am about 90 percent sure that cameras on android phones DO NOT have the capability to 'see' IR light.
For your android to see in the dark, you would need an IR filter and some IR LEDs. An IR filter filters out everything EXCEPT IR light. They will look like black pieces of glass or plastic and be almost impossible to see out of.
Hope this helps.
morrow.chris.n 9 years ago
Actually, Chad, most cameras on cell phones on the market now, have the capability to see IR. This does not mean they can see in the dark, but they can see IR light that is reflected off of items in the camera's view. During my time as a helicopter electronics technician, I would verify the operation of the IR lights on the helicopters by using my cell phone's camera. You could not see the lights without the camera, but bright as day with the camera. You do not need an IR filter, unless all you want to see is the IR. This would help only if the IR (such as a temperature variation) was all you are focusing on. For a security camera, you need something that can generate invisible light that the camera can pick up...hence, the IR light pack. CraigH4...the IR lights can be bought either online, or even in your local Radio Shack. Ask them for IR LEDs. But, for a security camera, I suggest buying a pack that is prebuilt, for ease.
hope this helps.
http://www.dx.com/p/ir-48-led-infrared-illumination-light-for-night-vision-dc-12v-500ma-15235#.VNDX3kVOm_I
I plan to try this when I get home, and will report back what I find. I think it will be as easy as this makes it sound.
Chris
OptimumAlliance 9 years ago
I'm sure that most android cameras can 'see' IR light, I know for a fact that my nexus 4 does. But there are some phones which filter out IR light, like the iPhone 5s.
Hi, basically cameras can see things that we can't. If you point a tv remote at a camera and press a button, you will see the LED flash through the camera but not through your own eyes. If you get powerful enough infra-red LEDs, they will light up a room to the camera but not to human eyes, this is how night vision equipment works.
As an example, look at this: http://www.amazon.co.uk/SecurityIng-Colorful-Secur...
You can see a ring of infra-red LEDs around the edge that will enable the camera to see in the dark.
Doctor90250 9 years ago
https://play.google.com/store/apps/details?id=usbwebcam.application
ywar.tar 9 years ago
Marcaine Art 11 years ago
TedRobotBuilder 10 years ago
TakashiMoto 11 years ago
