Introduction: Angle Grinder Stand
I decide made this angle grinder stand, to be able to cut off straight metal or wood and cut exactly angle, which I want.
It cost me about 20$.
Step 1: Cutting Material
First cut three pieces of this
First 530mm, second 380mm and third 170mm.
Step 2: Make Hinge
Next connect this two pieces with screw and nuts.
And hinge is done.
Step 3: Painting Parts
Beware to ventilate enough.
Step 4: Connecting Stopper.
These profiles has hole thought, which are good for making whorl M5.
Step 5: Attaching Grinder
The grinder is attached with bolt M10. The screw passes through upper part of stand and is attached into hole on grinder, which is serving to connect handle.
Step 6: Add Spring.
The spring hold very vell even without holes or some else holder.
Because of this spring will angle grinder come back to main position.
Step 7: Shift
To make shift, we must add one more profile, to attach rails to it.
I used these "L" pieces and special nuts to connect it together with grinder stand.
Step 8: Attaching Rails
These rails are for drawer and pair cost about 3$ and it works pretty well.
I drill two holes for each rail, into aluminium profile with 4,6mm borer and made M5 whorl. Then I was able to attach rails with profile with little screw M5
Step 9: Connecting Table
I connected this piece of wood with two screws. They were little bit long, as you can see on the photo so I cut them off and it's fine
