Arduino Bluetooth PC Fan Wind Sensor With RemoteXY
Intro: Arduino Bluetooth PC Fan Wind Sensor With RemoteXY
This projects is a mix of two of my main passions, Arduino and Wind. Here is a simple project that I used this OLD PC fan as a small wind generator to sense the wind speed.
Here we are using modified PC fan as a wind speed sensor using Arduino and showing the results on a smartphone running the RemoteXY application.
Background
The PC Fan is a brushless DC motor and has a permanent magnet. Normally, a DC motor with a permanent magnet can act also as a generator without any modification as you turn the rotor.
But the PC Fan is brushless DC motor with an electronic commutator.
The Magnet is the rotor and the coils are the stator. In motor operation, the rotating magnetic field is generated by the electronic commutator circuit.
As you start to rotate the PC Fan blades, the magnet also rotates and produces voltage inside the stator coils.
But the problem is that the electronic commutator circuit blocks the induced voltage from getting outside the PC Fan terminals as it only acts in one direction (from the terminals to the coil and not the other way).
The main idea behind the modification is the removal of the electronic commutator IC and connect the terminals to the coils to take the induced voltage from the PC Fan as a generator.
The modified PC Fan can generate small voltage (about 3 to 4 volts) and it’s enough to light an LED or charge your smartphone. So you can call it a PC Fan Wind Turbine.
Here are detailed steps and videos on the modification process.
https://www.instructables.com/id/Old-PC-Fan-Wind-Turbine-in-10-Minutes/
STEP 1: Components Used
PC Fan wind Turbine
This is a modified PC Fan that can generate small voltage (about 3-4 Volts)
Arduino UNO Banggood , ebay , aliexpress
Bluetooth Module HC-06 Banggood , ebay , aliexpress
Wires
Crocodile Clips
Smartphone running RemoteXY application
STEP 2: Connection of the Circuit
STEP 3: RemoteXY Interface
Open RemoteXY.com website.
Download RemoteXY to your smartphone.
Open RemoteXY Editor and Create new project.
Click Configuration
Click Connection and Choose Bluetooth
Click Module and Choose HC-06
Click Device and Choose Arduino Uno
Click IDE and Choose Arduino IDE
On the Module interface the Connection type to be Software Serial and Choose Connections 2 RX and 3 TX
Choose the default baud rate to be 9600
From Indication,
Add Level Meters and customize them as you like.
Add the text box tool.
From Decoration,
Add labels and customize its text and colors.
From View,
Change the interface background and you like to be.
STEP 4: Arduino Code
On the RemoteXY website save your project and click Get Source Code button.
Copy the generated Software and paste it into Arduino IDE.
Add the following lines of the code in loop() function to use the level meters and the text box.
RemoteXY.level_1 = ( analogRead(sensorPin) /5 ) ;
RemoteXY.level_2 = analogRead(sensorPin);
dtostrf(analogRead(sensorPin), 0, 1, RemoteXY.text_1);
Download the RemoteXY library and add it to the Arduino environment.
Compile the software, connect Arduino UNO board and upload the code to Arduino UNO.
STEP 5: Test the Circuit
STEP 6: Notes
- The voltage generated from the PC Fan is small and will not hurt the Arduino analog input pin. But if you’re concerned about that you need to connect a regulator or a voltage divider circuit.
- You can change the coefficient multiplied by the analog input to get the wind speed.
Here are some of my latest books on Amazon.
4 Comments
maheralrawashdeh 1 year ago
سؤالي كيف استطيع تحويل الفولتج الى سرعه الرياح
ممكن لو سمحت تشرح طريقه عمل البرمجه
ahmedebeed555 12 months ago
ساجربها ان شاء الله
