Arduino Camera Stabilizer DIY
Intro: Arduino Camera Stabilizer DIY
I made a Camera stabilizer using arduino for a school project.
You will need :
1x Arduino Uno
3x Servo motor
1x Gyroscope MP6050
2x Button
1x Potentiometer
1x Breadboard
( 1x External power supply )
STEP 1: Step 1 : Building the Circuit
Connect the wires as following
( Notice Which servo is connected to which pin and which button is connected to which pin, since this will determine its function later on )
MP6050 :
SCL to Analog Pin A5
SDA to Analog Pin A4
INT to Digital Pin 2
Servo 1 : Digital Pin 9
Servo 2 : Digital Pin 10
Servo 3 : Digital Pin 11
Button 1 : Digital Pin 7
Button 2 : Digital Pin 8
Potentiometer : Analog Pin A0
STEP 2: Step 2 : Code
before you use this code, make sure you have the right library's for the MP6050
(https://github.com/jrowberg/i2cdevlib/tree/master/...
this code will set it up so that 2 servo's will counter the rotations, and the 3rd servo will be controlled by the potentiometer. also it will add 2 buttons. button 1 which, when held, will stop the stabilizing process and make all the servo's return to their center position, and button 2, which will set a new orientation point. ( only use button 2 when button 1 is also pressed since else you set the current orientation location as a new orientation location. )
STEP 3: Step 3 : Building
I have a template for a 3d model of the frame, with cut in holes for the servo motors and the servo heads to connect which you can download and 3d print. or you could use these configurations to make it out of another material, like wood ( make sure you don't use too heavy material, since the servo's will not be able to hold it up )
Arduino Case :
2x an 11 by 8 cm piece
2x an 8 by 4 cm piece
1x an 11 by 4 cm piece
Handheld base :
4x an 15 by 3 cm piece
1x an 3 by 3 cm piece
Arm 1 :
1x an 15 by 4 cm piece
1x an 12 by 4 cm piece
Arm 2 :
2 motor holders :
4x an 2.8 by 2.3 cm piece
2x an 2.8 by 1.3 cm piece
STEP 4: Step 4 : Enjoy :D
You can now enjoy your self made camera stabilizer. If it locks up or starts glitching a quick reset on the arduino should be enough to get it running again.
I hope this was usefull in anyway and that you will enjoy the project you are working on! :D
7 Comments
JohnW51 6 years ago
You failed to mention what this thing is supposed to do. You should explain what it does and how it does it. Also, include a video that shows it in action preferably with sound track explaining what it's doing.
KumaNatsu 6 years ago
SanderI 6 years ago
yup, i tried with the LSM6DS3 first, but couldn't get it to work
Harsh Dethe 6 years ago
Swansong 6 years ago
That could be really useful, neat design :)
SanderI 6 years ago
thank you! :D
