Remote Controled Rubberband Gun
Intro: Remote Controled Rubberband Gun
Haven't you ever wanted to be able to press a button to ward away unwanted intruders? Well now you can with just a few simple steps, but first you'll need some supplies.
You will need:
- An Arduino board (any model should work)
- A rubber band gun (I just made one out of some wood scraps and a cloth-line clip used as a light trigger)
- A battery pack (at least 9 volts)
- An infrared remote and reciever
- A small servo motor
- Rubber bands
- And tape
Submitted by Powell Middle School for the Instructables Sponsorship Program.
You will need:
- Rubber bands
- And tape
STEP 1: Wiring Up the Arduino
1st- hook up the 9g Servo motor to the number 9 pin.
2nd- hook up the infrared receiver to the number 11 pin.
3rd- feel semi-accomplished and make sure it looks something like this..
STEP 2: Programming the Arduino
1st-You will need to include the IR library in Arduino (Here is a link)
2nd- Put in the code (Attached)
3rd- Use the #1 button to open the servo and the #2 button to close it
Here is the code-
#include <Servo.h>
#include <Ultrasonic.h>
#include "IRremote.h"
#define TRIGGER_PIN 12 // Ultrasonic sensor TRIGGER
#define ECHO_PIN 13 // Ultrasonic sensor ECHO
#define DISTANCE 20 // in Centimeters
#define WAITING 5000 // in milliseconds so this is 5 second.
#define SERVO_PIN 9
#define CLOSE_POS 90 // servo in CLOSE/UP position
#define OPEN_POS 180 // servo in OPEN/BACK position
/*-----( Declare Constants )-----*/
int receiver = 11; // pin 1 of IR receiver to Arduino digital pin 11
/*-----( Declare objects )-----*/
IRrecv irrecv(receiver); // create instance of 'irrecv'
decode_results results; // create instance of 'decode_results'
/*-----( Declare Variables )-----*/
//Ultrasonic ultrasonic(TRIGGER_PIN, ECHO_PIN);
Servo myservo; // create servo object to control the PEZ servo
void setup()
Serial.begin(9600);
myservo.attach(SERVO_PIN); // attaches the servo to pin
myservo.write(CLOSE_POS); // turn servo to CLOSE/UP position
Serial.println("IR Receiver Raw Data + Button Decode Test");
irrecv.enableIRIn(); // Start the receiver
void loop()
if (irrecv.decode(&results)) // have we received an IR signal?
// Serial.println(results.value, HEX); UN Comment to see raw values
translateIR();
irrecv.resume(); // receive the next value
// float cmMsec, inMsec;
// long microsec = ultrasonic.timing();
// cmMsec = ultrasonic.convert(microsec, Ultrasonic::CM);
// inMsec = ultrasonic.convert(microsec, Ultrasonic::IN);
//// this is for debugging
// Serial.print("MS: ");
// Serial.print(microsec);
// Serial.print(", CM: ");
// Serial.print(cmMsec);
// Serial.print(", IN: ");
// Serial.println(inMsec);
// delay(1000);
// void setup() /*----( SETUP: RUNS ONCE )----*/
// //Serial.begin(9600);
// Serial.println("IR Receiver Raw Data + Button Decode Test");
// irrecv.enableIRIn(); // Start the receiver
// }/*--(end setup )---*/
// void loop() /*----( LOOP: RUNS CONSTANTLY )----*/
// if (irrecv.decode(&results)) // have we received an IR signal?
//// Serial.println(results.value, HEX); UN Comment to see raw values
// translateIR();
// irrecv.resume(); // receive the next value
//}/* --(end main loop )-- */
/*-----( Declare User-written Functions )-----*/
void translateIR() // takes action based on IR code received
// describing Car MP3 IR codes
switch(results.value)
case 0xFF30CF:
Serial.println(" 1 ");
myservo.write(OPEN_POS); // tell servo to go to OPEN/BACK
break;
case 0xFF18E7:
Serial.println(" 2 ");
myservo.write(CLOSE_POS); // tell servo to go to CLOSE/UP
break;
default:
Serial.println(" other button ");
delay(500);
// myservo.write(CLOSE_POS); // tell servo to go to CLOSE/UP
// delay(15); // waits 15ms for the servo to reach the position
// myservo.write(OPEN_POS); // tell servo to go to OPEN/BACK
// delay(WAITING); // waits sometime to allow grabbing of candy pellet
Here is the code-
#include <Servo.h>
#define SERVO_PIN 9
void setup()
Serial.begin(9600);
void loop()
translateIR();
// delay(1000);
// translateIR();
case 0xFF30CF:
break;
case 0xFF18E7:
break;
default:
delay(500);
STEP 3: Hooking Up the Gun
1st- Tape the servo to the top of the gun so that the arm moves up when the 1 button is pressed.
2nd- tie/tape a string to the servo arm and gun trigger
3rd- Attach the Arduino and the battery pack to the side of the gun it should look somewhat nice, like this...
STEP 4: Test!
Test it! I will attach a video of it operating.
Kamokaki 10 years ago
hi im trying to controll my arduino to move a servo.
Could you help me put in the code?
The controll gives off the infrared as i press left: FF22DD and right FFC23D. Please help me figure this out.
#include <Servo.h>
#include <IRremote.h>
unsigned long Value1 = 0xFF22DD; // where XXXXXXXX is on our your remote's values
unsigned long Value2 = 0xFFC23D; // where XXXXXXXX is another button on your remote
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
Servo servo1;
// the setup routine runs once when you press reset:
void setup() {
Serial.begin(9600);
// initialize the digital pin as an output.
servo1.attach(10); // attack servo to digital pin 10
// the loop routine runs over and over again forever:
void loop() {
if (irrecv.decode(&results)) {
irrecv.resume(); // Receive the next value
if(results.value == Value1) {
servo1.write(160);
else if (results.value == Value2){
servo1.write(75);
