Arduino DS3231 RTC Clock With LCD
41,251
56
21
Introduction: Arduino DS3231 RTC Clock With LCD
To familiarize myself with a DS3231 RTC (real time clock), I built a simple arduino based 24 hour clock. It has 3 buttons with the following functions: press any button to enter the time setting mode, increase and decrease the time in minutes with two of the buttons, and set the clock with the third button. You can checkout a video of it working at vimeo.com/andrewideas/simplearduinoclock.
Materials Required:
  • An arduino development board (I used an Uno)
  • A standard 16x2 HD44780 based LCD display
  • A DS3231 based RTC (I got mine on Amazon)
  • Three push buttons
  • Three resistors (~10K ohm)
  • A potentiometer (~10K ohm)
  • A breadboard
  • Several jumper wires
Step 1: Wiring
Refer to the drawing for wiring instructions. The buttons are connected to pins A0, A1, and A2. The RTC uses pin A5 for SCL and pin A4 for SDA. The potentiometer varies the contrast on the LCD and the LCD uses digital pins 2 through 7.
Step 2: Programming
Use the arduino IDE to upload my sketch to your arduino.
My code was partly based on the code provided here. And, of course, my code is explained in its comments.
You can download the sketch from this instructable.
Step 3: Continuing on With Your Life
You did it! Unless you didn't- in which case comment below and I'll do my best to help you out. Otherwise, go on ahead and do even greater things!
Thanks!
3 People Made This Project!
  • Organization Contest
  • Back to School: Student Design Challenge
  • 3D Printed Student Design Challenge
21 Comments
Ωραία
Ωραία
10 months ago
I need help. I have wired it all perfectly but I can't figure out any of the code. Can you mabey put the code used in the reply? Also great project
anguyen211
anguyen211
3 years ago
I have all the wiring and coding right, and the LCD lights up and the potentiometer works perfectly. The problem is that the time doesn't show up on the LCD screen, and it only shows a blank screen with squares. Suggestions?
Darknessblade.
Darknessblade.
Reply 2 years ago
this is due your display having a different pinout.
i had the same issue with a 10 pin display, the thing you can try is with jumper cables and a breadboard, to find the correct pinout. {and yes this is a hard thing to do}
for my 10pin one it took me over a full day to find the correct one.
use the hello world code for a simplified testing.
you need to reboot the arduino everytime you try a new pinout
AndrewIdeas
AndrewIdeas
Reply 3 years ago
If your LiquidCrystal library isn't working, this would explain the LCD not displaying anything, getting the library loaded in your IDE and in your sketch should solve this.
ian9au
ian9au
3 years ago on Introduction
a good Indestructable. Keep up the good work.
AndrewIdeas
AndrewIdeas
Reply 3 years ago
Thanks for the kind words!
anguyen211
anguyen211
3 years ago
Also I can't seem to upload the BasicClock.ino to my library and sketch. It says library not found. Maybe there is an updated version or I can use a different ds3231 library for it?
AndrewIdeas
AndrewIdeas
Reply 3 years ago
On my installation of the Arduino IDE the Wire and LiquidCrystal libraries were both included. Check out https://www.arduino.cc/en/Guide/Libraries for help checking if you have these, and if not you should be able to use the library manager to install them. Thanks!
MarloG1
MarloG1
4 years ago
good day, can i use this as a stopwatch with lap times?
AndrewIdeas
AndrewIdeas
Reply 4 years ago
Hey, this project was designed to be a clock rather than a stopwatch. However, you could use a similar hardware design and make use of the RTC to keep good time and print the output to the LCD.
Thanks!
MarloG1
MarloG1
Reply 4 years ago
thank you for your reply,
however i'm new to this and trying to learn arduno, can guide me,
thank you
AndrewIdeas
AndrewIdeas
Reply 4 years ago
This doesn't include a rtc, but an rtc is not as important in a stopwatch application anyway.
http://fritzing.org/projects/arduino-lcd-stopwatc...
It is a simple stopwatch, and if you want to incorporate an rtc simply connect it to I2C like I did and use the setRTCTime() and readRTCTime() methods to access the time from the rtc. From there, you should be able to use arithmetic to calculate the passing of time.
Best of luck!
MarloG1
MarloG1
Reply 4 years ago
thank you so much for your help
MarloG1
MarloG1
Reply 4 years ago
thank you very much for your help
bicchef
bicchef
4 years ago
having trouble and not sure how the time should look in the code i just get a back lit screen doesn't respond to the potentiometer anyone that can help me.
thanks
AndrewIdeas
AndrewIdeas
Reply 4 years ago
The format for the parameters of setRTCTime() is (sec, min, hr, day of week, day of month, month, year)
For example: setRTCTime(0, 3, 23, 4, 15, 7, 17);
Hope this helps!
MahmoudE36
MahmoudE36
5 years ago
your instructable is very awsome
i am a very very new in arduino big world ,,,
and i need help in my second or third arduino project.
i need to build a code that repeat it self every 24 hour "every day"
without RTC module
Example like:
at 9 clock "pin 3 High"
at 11 clock "pin 4 High"
at 18 clock "pin 5 High"
at 20 clock "pin 6 High"
at 22 clock "pin 7 High"
and repeat that commands every 24 hour ""every day"
can you help me with that
AndrewIdeas
AndrewIdeas
Reply 5 years ago
Without an RTC you will run the risk of loosing time accuracy over time, but you can accomplish something what you are asking about by using the delay function. I quickly wrote up a sketch to do what I think you are describing and put it on my site at: http://andrewideas.weebly.com/arduino-delay-pract...
Hopefully you can use this code to work on your project, but bear in mind I have not tested it. None the less, it should be a good starting point for you. Thanks!
MahmoudE36
MahmoudE36
Reply 5 years ago
Many many thanks for you AndrewIdeas , and I am very happy for your concern
i will test it and feed you by results
