Arduino - Door Event Logger
Intro: Arduino - Door Event Logger
Ok, so for my first instructable I thought to share something I've just made today.
It's a logger for anything really that consist's of something being on or off ( in the door case, open / closed ).
For this to be applied to a door, the push-button has to be replaced to something like an hall effect sensor ( which I don't have thus the button).
All'right, what i've used:
- Arduino UNO
- DS1307 Real Time Clock
- SD shield ( from this instructable: https://www.instructables.com/id/Arduino-DIY-SD-Card-Logging-Shield )
- 1 led
- 1 push-button
- 220 ohm resistor , 10k resistor and hook-up wire
- Arduino UNO
- 1 led
- 1 push-button
STEP 1: Connecting the Parts
SD card pins:
** MOSI - pin D11
** MISO - pin D12
** SCK - pin D13
** CS - pin D4
+ GND, 5v, 3.3v
RTC pins:
** SDA - A4
** SCL - A5
** GND - GND
** VCC - 5V
Button + led pins:
** Led's - to 220ohm resistor to GND
** Led's + to D3
** Connect the button to 5V and D2
** Connect 10k resistor from D2 to GND
** MOSI - pin D11
** MISO - pin D12
** SCK - pin D13
** CS - pin D4
+ GND, 5v, 3.3v
RTC pins:
** SDA - A4
** SCL - A5
** GND - GND
** VCC - 5V
Button + led pins:
** Led's + to D3
STEP 2: The Code
As for the sketch, download it below.
External library used: adafruit's ds1307 lib ( https://github.com/adafruit/RTClib )
Now, to explain a few things:
variables:
* ok - it stop's the loop if the sd card was not initialized correctly
* first - it log's the first state, and then wait for the state to change before logging it again
functions:
* time() - get the time from RTC and convert it to a string
* SDwrite(int state) - write's on the SD card the time and a message depending on the state it receive's (1 or 0)
* call(int buttonState) - it's used to turn off/on the led and trigger the SDwrite() function
Feel free to contact me for any additional information.
That's it for my first instructable, I'm waiting for feedback.
variables:
functions:
STEP 3: UPDATE: Replaced the Button With Hall Effect Sensor
As promised I've replaced the button with a proper sensor for this project: a hall effect sensor.
The sensor I bought is called A3144 (got it off ebay). It has the following pin-configuration: VCC - GND - OUT.
Now to connect it to arduino, just remove the button and do the following.
VCC - to 5V
GND - GND
OUT - D2
* the 10k resistor still remains connected between 5V and D2
The sketch need's a little editing, as the sensor is essentialy an normally open switch and it was previously configured for an normally closed switch.
There are 3 lines of code that need to be modified:
if (buttonState == LOW) to if (buttonState == HIGH)
if (state==LOW) to if (state==HIGH)
In the picture the sensor is taped to the door frame and the magned is fixed with double-sided tape to the door.
** The hall effect sensor have polarity.
The next stage is to add a remote control switch receiver and transmitter to make the sensor wireless.
VCC - to 5V
GND - GND
OUT - D2
5 Comments
marceldevuyst 2 years ago
botronics 2 years ago
sreekanthmp 4 years ago
void SDwrite(int state)
String message = "";
if (state==LOW)
{message = "OPEN";}
else
{message = "CLOSED";}
I can't under stand this function .How the "state" co related with "buttonPin" position.
netman311 4 years ago
backinthelab 9 years ago
I'm a complete noob when it comes to arduino, so this really helped me out. Thanks! I made some modifications based on my particular use, such as omitting the LED, and changing some of the output text, but it works beautifully with the code provided. Essentially, I'm prototyping a data logger for use in my weld shop. When a weld fixture is loaded, it will actuate a spring pin that will hold down a button. When unloaded, the button will be released. This will give me the exact time that it takes for an assembly to be completed. The only other thing I'd like to do is have it log duration instead of a timestamp, but it's usable as-is so I'll igure out how to do it at some point. Once I get this off of the breadboard and solder up a working model, it should work great! Probably will make 10-15 more to cover the whole shop! Thanks again!
