Arduino Examples #2 Use an Arduino As a FTDI Programmer
Intro: Arduino Examples #2 Use an Arduino As a FTDI Programmer
In this instructable I will show you how to use an Arduino Uno, Duemilanove, Diecimila, Mega 2560, Mega 1280 or Nano to program an Arduino Pro, Pro Mini, Mini, LilyPad or any other device with a ATmaga168, ATmaga328 using an Arduino. But this only works on 5v boards NOT 3.3v boards. If you have any questions, comments or suggestions for other Arduino examples please feel free to leave a comment and I will write back as soon as i can.
STEP 1: Get the Hardware Required
Hardware Required
1-arduino Duemilanove, Diecimila or Nano
1-6 pin female header
6-jumper wires
6-jumper wires
STEP 2: Wire It Up (5v Boards)
First you should remove the micro controller from the board you don't want to program or else you will be programing both micro controllers. Next connect jumper wires between the Arduino and header as shown in the photo below. Then go to the next step to program the Arduino.
STEP 3: Program the Arduino
Now using your computer open up the Arduino software. Then connect your 2 Arduino's together and to your computer. Next go to tools and select the board you want to program After that if you want to test it out you can copy and paste all the text between the //. Then upload the program to your Arduino and the led connected to pin 13 should blink.
void setup() { // this sets the output pins
pinMode(13, OUTPUT); // Pin 13 has an LED connected on most Arduino boards:
void loop() {
digitalWrite(13, HIGH); // set the LED on
delay(1000); // wait for a second
digitalWrite(13, LOW); // set the LED off
void loop() {
47 Comments
Yeem 4 years ago
36000hz 4 years ago
Ali Qureshi 5 years ago
AdityaB102 5 years ago
magnocampos 7 years ago
That's a nice tutorial for arduino UNO, but, if you want to use Arduino nano?? best regards, Campos
goldenshuttle 7 years ago
arduino mini is the only shitty Arduino product. always stubborn to take code.
FirdousP 8 years ago
SrikerD 8 years ago
how can i program my promini 3.3v,8mhz with arduino uno is there any way to do this, please reply me asap i m in hurry
thank u in advance
longtomo 9 years ago
How can I upload sketch to Pro Mini using Mega2560?
I can't seem to do so
aephy6 8 years ago
I guess you cant do it with Mega2560, cause you cant remove the Atmega2560 IC from it, and when you connect it, the arduino IDE will detect the 2560, not the Pro mini
Lotrax 9 years ago
I did exactly as you said, but I get this error message: avrdude: ser_open(): can't set com-state for "\\.\COM12"
What does this mean? Everything is connected correctly, I removed the AtMega from the UNO.
victor.valadez.547 9 years ago
There is a good tutorial titled: "Arduino Uno R3 as a true ISP programmer for any Attiny and Atmega AVR", see:
You can upload any hex file you want in any AVR micro-controller just using "avrdude" and an Arduino Uno R3 board that runs ArduinoISP.
Omkar_R 9 years ago
I want to upload program on 'Arduino Pro Mini 328 3.3V /8MHz' using 'Arduino Uno'. What procedure would I have to follow?
ayesh.kahawala 9 years ago
when i upload my Program to arduino pro mini (5v) using uno it show me " avrdude.exe: stk500_getsync(): not in sync: resp=0x00 " and it doesn't work ... can anybody help me ??
motxpo 9 years ago
I've had the same problem. Researching on another thread (
https://www.instructables.com/id/Uploading-sketch-to-Arduino-Pro-Mini-using-Arduino/) , the RESET pin on UNO R3 on that thread is linked with GRN pin on Mini (5V), and not with BLK pin as this thread indicates. The others pins follows the same as indicated here. So just change the RESET pin on UNO to be wired with GRN pin on Mini and NOT with BLK pin.. It worked for me. Hope this can help you. ;-)
lucas.golino 9 years ago
CTS and GND is connected in GND on arduino?
JuliusR 9 years ago
Can someone please tell me where I can find the corresponding pins on a arduino nano. I can't find pins labelled: RTs, Rxd, Txd, Vcc,Cts, Gnd .
Please someone help me to identify the right pins on my arduino nano so I can program it from my arduino uno. My nano is playing up and I can't program it the conventional way, so much help is appreciated.
danny2707 9 years ago
when i go to upload the .ino sketch which board i have to select into tools->board->(Arduino UNO or Arduino Por or Por mini 5v)... it's just valit to 5v nano no for 3.3 volts?
Trey Frost 13 years ago
qazwsx755 13 years ago
