Introduction: Arduino GRANDE the Huge Microcontroller
We love Arduino! But the boards are so tiny that they can be difficult to hug. And not so easy to see, either, if you're a student sitting at the back of a classroom. So why not solve both problems by building a really huge, fully-functioning Arduino that's six* times larger than real life?
This guide will show you how to build your own, using laser cut acrylic, a few LEDs and buttons, some wiring and connectors, and a puny little actual sized Arduino Uno as its brain.
*5.6x to be exact.
Step 1: Parts and Materials You'll Need
Here's what you'll need:
- 2 ea. 16"x12" 5mm thick blue/green acrylic sheet
- 7"x4" 6mm thick white acrylic sheet
- 2 ea. 12"x12" 6mm thick black acrylic cheet
- White acrylic craft paint
- Black acrylic craft paint
- Arduino Uno
- ScrewShield for Arduino
- 28 ea. banana jacks
- Banana plugs
- Stranded wire
- Panel mount USB A to B plug
- AAAx4 battery holder, batteries, and switch
- Doorbell or other momentary switch button with 58mm spacing mounting holes
- 4 ea. rectangular panel mount LEDs 7.75mm x 5.3mm, three yellow (L, TX, & RX), one green (ON)
- 4-40 screws (1", 3/4", and 1/2") and nuts
- Loctite thread locker
- Soldering iron and solder
- laser cutter
Note: The drawings in the next step are designed to fit these exact parts, so you may need to measure and redraft some screw mounting holes if you source different parts.
Step 2: Model Files
The first step I took in building this was to build a 3D model in Rhino. I based it on the Arduino Uno dimensions, and then started creating the parts based upon my real-world materials and scale. (Since I'm using an Epilog Zing 16 laser cutter with a bed size of 16" x 12", my maximum dimensions were dictated for me. So, this is actually a 5.6x larger-than-real-life Arduino.)
After building the 3D model, I extracted the curves and laid them out flat for laser cutting. Those files are attached here in .ai and .dxf formats. In the Illustrator document there are different layers for 6mm cutting, 5mm cutting, and etching.
Step 3: Prototype With Plywood
Not an essential step, but I chose to do a test on baltic birch plywood. It smells much better than acrylic.
Step 4: Laser Cut USB Jack, Power Jack, Atmega 328p
The chip is just for show, but the power jack will eventually hide the batteries, and the USB port will be made functional by the addition of a panel mount USB jack.
Again, I prototyped first with some white acrylic before moving on to my final versions in black.
Also cut the header block parts and assorted chips, crystal, and capacitors found in the files.
Step 5: Laser Etch and Cut the Main "PCB" Board
Here the etching is used to create a relief that will eventually be painted white for a high-contrast PCB silkscreened look. Please make sure you've got good filtration and ventilation when cutting acrylic -- as Tod Kurt once said, it smells like you're burning frozen gasoline.
You can also dry-fit the other components to make sure everything fits nicely before moving on. Here's a look at the board with temporary white components in place.
Step 6: Paint the Etched Parts
The laser etching stands out fairly well on black acrylic, less so on the blue/green, and not at all on any white parts. You can improve the etching greatly with a little paint. This is a great trick I learned from Mark and Andy of Spikenzie Labs. You cover the etching with acrylic paint and then immediately wipe it off with a squeegee or cloth. The paint comes right off the smooth, unetched portion of the surface, but adheres nicely to the rough, etched parts. A little isopropyl alcohol on a cotton swab is useful for cleaning up any stubborn bits.
Step 7: Wire the Headers
Next, you'll insert the banana jacks into the female header blocks and then thread the nuts on to hold them in place. A dab of Loctite will prevent them from loosening up later.
On each banana jack, solder a length of wire sufficient to route through the board to the real Arduino. Push the wires through to the underside of the board at the header location, then insert and assemble the header blocks with screws and nuts which will be held captive in the acrylic t-slots.
Step 8: Assemble the Board
The reset button (originally sold as a doorbell) needs to have two long lengths of wire soldered to it, which are then fed through the board to route to the real Arduino. The same goes for the panel mount rectangular LEDs.
Insert and screw down all of the remaining components.
Step 9: Hook Up the Brains
Attach a real Arduino Uno to the board, and then run all of the header, reset, and LED wiring to it, and plug in the USB cable. You can use a ScrewShield -- available at Adafruit, SparkFun, Seeed, and other electronics resellers -- to prevent wires from falling out. Full disclosure, I'm one of the creators of the ScrewShield and will make a little bit of money if you buy one.
Tuck the unsightly wiring away under the protective bottom board. You can adhere rubber feet to the bottom for stability.
Step 10: Artisinally Craft a Beautiful Barrel Plug From Cardboard Tubing and Paint
There are surely better ways to do this -- 3D printing, or heating and bending ABS plastic both come to mind -- but this was what I did and it worked out for now.
Hide a 4xAAA battery pack inside the barrel plug, and then run it through a switch to GND and Vin on the Uno to power the Arduino GRANDE.
You can now upload a test sketch and try things out! I wired banana plugs to resistors, 10mm LEDs, potentiometers, speakers, buzzers, servo motors, and other typical components to plug into the GRANDE.
Step 11: Enjoy and Share Your Arduino GRANDE
Now, you can upload any Arduino sketch of your liking, and wire standard components to banana plugs in order to insert and use with great effect on the GRANDE.
Carry your GRANDE everywhere you go to make a scene! At Bay Area Maker Faire, my friend (and Arduino creator) Massimo Banzi gave the GRANDE a big thumbs-up.
You can use yours to teach beginning Arduino classes in an interactive, hands-on way, carry it around like a boom box while playing chiptunes, or even extend the idea with GRANDE scale shields.
2 People Made This Project!
- Akin Yildiz made it!
- JohnPark made it!
69 Comments
Tip 8 weeks ago
But there is already the bigger version, its name is ArduOne: www.while1.eu/arduone/arduone.html
4 years ago
Its absolutely ridongculous.
Love it.
But I think you guys didn't try hard enough to get hold of an ATMEGA328 in that form factor. I mean, are you really sure Atmel don't have something lurking around?
Did you even ask?
Huh? Huh? Huh?
Reply 4 years ago
Doh. I forgot to ask.
6 years ago
OOh I would love to give one of these to my kids!
6 years ago
6 years ago
this is rad! but i feel like this may get discovered by the fans of ariana grrandes brother......could be dangerous
Reply 6 years ago
Haha, I didn't think of that! There MUST be a relative named Arduino somewhere back in Ariana's family tree, right?
6 years ago
As an Italian, I tell you... this (awesome) thing should be named "Arduone"
Reply 6 years ago
haha good pun sir, i had "ardukiddingme"
Reply 6 years ago
Andrebbe chiamato "Arduino grosso!" per poter fare i programmoni e accendere i leddoni.
La prossima versione dovrà essere chiamata "Arduino grosso più GROSSO!"
Reply 6 years ago
hahahahah Sio insegna :)
Reply 6 years ago
Reply 6 years ago
Reply 6 years ago
Mi piace! Grazie.
6 years ago
Cool
6 years ago
This is too cool. I can see the movie coming soon - "Attack of the giant Arduino". Now the next challenge. Size it down so small we can no longer see it ! Or better yet, become an Arduino yourself for Haloween.
Reply 6 years ago
I would love to make an Arduino costume, good call.
6 years ago
this is a really creative project, and it's really cool.
Reply 6 years ago
Thanks Han!
6 years ago
Oh when I watch the photo say what???very funny project
