Arduino LCD Keypad Shield
Intro: Arduino LCD Keypad Shield
STEP 1: Library
You will need to install the Keypad library.
STEP 2: Code
Here is my modified code from the example code included with the library. I added the function to turn on the LED on digital pin 13 when the select button is pushed and to turn it back off then the select button is released.
STEP 3: NOTE:
Do not changed digital pin 10. This pin is used to control the back light of the LCD. If its set to output and high it may damage you LCD shield.
18 Comments
barish1903 3 years ago
Created by
Ark Bramwell, July 2010
Modified by keen
Date: 05/05/2017
Function: this program will test the LCD panel and the buttons
//Sample using LiquidCrystal library
#include <LiquidCrystal.h>
#include <Wire.h>
// select the pins used on the LCD panel
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
// define some values used by the panel and buttons
int lcd_key = 0;
int adc_key_in = 0;
#define btnRIGHT 0
#define btnUP 1
#define btnDOWN 2
#define btnLEFT 3
#define btnSELECT 4
#define btnNONE 5
// read the buttons
int read_LCD_buttons()
adc_key_in = analogRead(0); // read the value from the sensor
// my buttons when read are centered at these valies: 0, 144, 329, 504, 741
// we add approx 50 to those values and check to see if we are close
if (adc_key_in > 1500) return btnNONE; // We make this the 1st option for speed reasons since it will be the most likely result
if (adc_key_in < 50) return btnRIGHT;
if (adc_key_in < 195) return btnUP;
if (adc_key_in < 380) return btnDOWN;
if (adc_key_in < 550) return btnLEFT;
if (adc_key_in < 800) return btnSELECT;
return btnNONE; // when all others fail, return this...
void setup()
Serial.begin(9600);
lcd.begin(16, 2); // start the library
lcd.setCursor(0, 0);
lcd.print("Push the buttons"); // print a simple message
void loop()
lcd.setCursor(9, 1); // move cursor to second line "1" and 9 spaces over
lcd.print(millis() / 1000); // display seconds elapsed since power-up
lcd.setCursor(0, 1); // move to the begining of the second line
lcd_key = read_LCD_buttons(); // read the buttons
switch (lcd_key) // depending on which button was pushed, we perform an action
case btnRIGHT:
lcd.print("RIGHT ");
break;
case btnLEFT:
lcd.print("LEFT ");
break;
case btnUP:
lcd.print("UP ");
break;
case btnDOWN:
lcd.print("DOWN ");
break;
case btnSELECT:
lcd.print("SELECT");
break;
case btnNONE:
lcd.print("NONE ");
break;
Serial.print("Deger :" );
Serial.println(adc_key_in);
vveraa 5 years ago
void loop() {
lcd.setCursor(0,1);
case btnUP:
lcd.clear();
lcd.print(" up ");
break;
case btnDOWN:
lcd.clear();
lcd.print(" down ");
break;
brightled 5 years ago
TaranA3 5 years ago
I downloaded your sketch but when I tried to compile it I got the following error messages:
Arduino: 1.8.6 (Windows 10), Board: "Arduino/Genuino Uno"
FINA14KITKJE85T:6:1: error: 'DFR_LCD_Keypad' does not name a type
DFR_LCD_Keypad keypad(A0, &lcd);
C:\Users\taran\Downloads\FINA14KITKJE85T\FINA14KITKJE85T.ino:7:11: warning: uninitialized const 'KEY_RIGHT' [-fpermissive]
const int KEY_RIGHT;
FINA14KITKJE85T:8:19: error: expected initializer before ':' token
const int KEY_LEFT:
C:\Users\taran\Downloads\FINA14KITKJE85T\FINA14KITKJE85T.ino:10:11: warning: uninitialized const 'KEY_DOWN' [-fpermissive]
const int KEY_DOWN;
C:\Users\taran\Downloads\FINA14KITKJE85T\FINA14KITKJE85T.ino:11:11: warning: uninitialized const 'KEY_NONE' [-fpermissive]
const int KEY_NONE;
C:\Users\taran\Downloads\FINA14KITKJE85T\FINA14KITKJE85T.ino: In function 'void setup()':
FINA14KITKJE85T:22:11: error: 'led' was not declared in this scope
pinMode(led, OUTPUT);
C:\Users\taran\Downloads\FINA14KITKJE85T\FINA14KITKJE85T.ino: In function 'void loop()':
FINA14KITKJE85T:29:14: error: 'keypad' was not declared in this scope
last_key = keypad.get_last_key();
FINA14KITKJE85T:39:12: error: the value of 'KEY_RIGHT' is not usable in a constant expression
case KEY_RIGHT:
C:\Users\taran\Downloads\FINA14KITKJE85T\FINA14KITKJE85T.ino:7:11: note: 'KEY_RIGHT' was not initialized with a constant expression
case KEY_RIGHT:
FINA14KITKJE85T:43:12: error: 'KEY_UP' was not declared in this scope
case KEY_UP:
FINA14KITKJE85T:47:12: error: the value of 'KEY_DOWN' is not usable in a constant expression
case KEY_DOWN:
C:\Users\taran\Downloads\FINA14KITKJE85T\FINA14KITKJE85T.ino:10:11: note: 'KEY_DOWN' was not initialized with a constant expression
const int KEY_DOWN;
case KEY_DOWN:
const int KEY_DOWN;
FINA14KITKJE85T:51:12: error: 'KEY_LEFT' was not declared in this scope
case KEY_LEFT:
FINA14KITKJE85T:55:12: error: 'KEY_SELECT' was not declared in this scope
case KEY_SELECT:
FINA14KITKJE85T:61:12: error: the value of 'KEY_NONE' is not usable in a constant expression
case KEY_NONE:
C:\Users\taran\Downloads\FINA14KITKJE85T\FINA14KITKJE85T.ino:11:11: note: 'KEY_NONE' was not initialized with a constant expression
const int KEY_NONE;
case KEY_NONE:
const int KEY_NONE;
exit status 1
Invalid library found in C:\Users\taran\Documents\Arduino\libraries\keypad_values: C:\Users\taran\Documents\Arduino\libraries\keypad_values
Invalid library found in C:\Users\taran\Documents\Arduino\libraries\Yahzee: C:\Users\taran\Documents\Arduino\libraries\Yahzee
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
philngai 6 years ago
Thanks, your library and example sketch worked perfectly for me!
robmawe91 6 years ago
Your welcome.
christmasbob 6 years ago
the range of resistance for the up button was set too low. it is closer to 150 ohms. I fixed it in the DFR_LCD_Keypad.h file.
.#define DFR_LCD_KEYPAD_KEY_UP_ADC_LOW 120
#define DFR_LCD_KEYPAD_KEY_UP_ADC_HIGH 160
works now
RobM230 6 years ago
demo_simple:14: error: 'DFR_LCD_Keypad' does not name a type
demo_simple.ino: In function 'void loop()':
demo_simple:30: error: 'keypad' was not declared in this scope
demo_simple:42: error: 'KEY_RIGHT' was not declared in this scope
demo_simple:46: error: 'KEY_UP' was not declared in this scope
demo_simple:50: error: 'KEY_DOWN' was not declared in this scope
demo_simple:54: error: 'KEY_LEFT' was not declared in this scope
demo_simple:58: error: 'KEY_SELECT' was not declared in this scope
demo_simple:62: error: 'KEY_NONE' was not declared in this scope
I am a newbee with Arduino but am trying to learn C++, but would appreciate any suggestions you might have to fix it. Thanks, Rob
I got the same error when compiling on 1.8.1. I discovered that the Library file was in the wrong file directory on my PC. Once I moved it to the right spot it compiled fine for the Uno. I'm not sure if Arduino changed something with the newer IDE or I messed something up transferring everything to my new computer... I will go ahead and download the newist IDE and see if it will compile for me.
RobM230 6 years ago
Thanks. I'll make sure my files are in the correct place as well. Just very frustrating to copy someone else's code - which works - and find I can't compile it or there are error messages. Again, thanks for your help and interest.
Thats the only thing I can think of. I uninstalled the Arduino IDE and deleted all my files, installed the newest IDE and added all my files back to the correct directory. Ran the code and it compiled with out any errors. I know it can be very frustrating, I have found many codes were their is some sort of problem. Most of the time it seems to be with the library's either something is wrong or it can't be found online anymore. Hope you get this working!
RobM230 6 years ago
Great advice! I uninstalled then reinstalled IDE 1.8.5. Had moved all my libraries and renamed the folder. Then downloaded new libraries and made sure I put them in the right (Libraries) folder with proper names. Everything works now and I have a functional LCD shield-RTC-Uno clock! Thanks so much for your help. Regards, R
Awesome! Glad you got it working.
Did you download and instll the library?
RobM230 6 years ago
I did, or at least I think I did, as they show up in the sketch. I tried in both IDE 1.8.5 (compiling error) and 1.0.5. Here are the screen shots. And thanks for your help!
Ramkulov 6 years ago
Thanks !
VictorC13 6 years ago
Hi
Thank you for such great information, I now have a functional LCD. The only issue is that the UP button does not work, could it be that I have a broken LCD shield? I am using a shield made by SainSmart. Thank you again
Victor
It could be the LCD shield or to code. I'm
not sure if yours works the same as mine. You can check the shield by
using a multimeter and check the continuity of the button and then
follow the traces to the pins and recheck. You should only have
continuity if the button is pressed. If that checks out it could either
be a problem with the Arduino GPIO connectors (they ware out over time)
or could be a problem with the library Pinout. If thats the case you can
modify it or #define in the sketch.
