Arduino Leonardo As ISP
Intro: Arduino Leonardo As ISP
The Leonardo was my first Arduino, I bought it because it's native USB capabilities. After experimenting with Arduino, I decided to migrate from my Arduino Leonardo to a standalone Atmega328p or, for smaller projects, to a microcontroller from the Attiny family.
After some research I found this guide by PeterVH: http://petervanhoyweghen.wordpress.com/2012/09/16/arduinoisp-on-the-leonardo/
After several failed attempts, I was able to burn the bootloader and upload sketches successfully and wanted to share that with this Instructable.
Disclaimer
I can not be held responsible for any damages that could occur to you or your equipment while following the procedures present on this page. Also, I give absolutely no warranty on the correctness and usability of the information on this Instructable. Please note, however, that these procedures have worked in my case without any damages or problems.
STEP 1: Materials
- A computer (all steps are based on computer running Windows)
- Wires
- Target Atmel microcontroller
STEP 2: Preparing the Leonardo
1- Open Arduino IDE
2- Open the ArduinoISP sketch (File/Examples/ArduinoISP)
3- Change the following lines (see picture 1):
#define RESET SS TO #define RESET 10
#define LED_HB 9 TO #define LED_HB 13
( we want to use digital pin 10 to reset the target and we are setting the heart beating led on pin 13)
4- Save the sketch as LeonardoISP (so you can use it later)
5- We choose Arduino Leonardo (Tools/Boards/Arduino Leonardo) and the appropriate Serial Port (Tools/Serial Port/COM **)
5- Upload
If the sketch was uploaded correctly, you will see the on-board led (the one marked as L) doing a heartbeat sequence.
Now, on your Arduino IDE folder:
1- Create a new folder in "hardware" with the name of leofix
2- Open a text editor and paste this code (picture 2):
arduinoispleo.name=Arduino as ISP (Leonardo)
arduinoispleo.communication=serial
arduinoispleo.protocol=arduino
arduinoispleo.speed=19200
Save the file as programmers.txt (see picture 3)
Next we connect some wires to our Leonardo (picture 4):
Digital Pin 10,1(TX),0(RX)
ICSP MISO,5V,SCK,MOSI,GND (see 6pin pinout on picture 5)
STEP 3: Target Atmel Microcontroller 1: Atmega328p (materials)
You need this:
(Source: http://arduino.cc/en/Tutorial/ArduinoToBreadboard)
For external 16Mhz crystal configuration:
-Atmega328p
-10k Ohm resistor (I used 22K) x1
-16 MHz clock crystal x1
- 22 pF capacitors x2
(or you could just buy any of these kits, like I did:
Virtuabotix Bareduino - Bare minimum 16 MHz Arduino Kit
Virtuabotix Bareduino Plus- Arduino Compatible Microcontroller with Power Regulator
Both are bootloaded as Duemilanove, so you save a step)
For Minimal Circuit (Eliminating the External Clock) configuration:
-Atmega328p x1
STEP 4: Target Atmel Microcontroller 1: Atmega328p (assemble)
See picture 1
Also you can follow this guide:
https://www.virtuabotix.com/product-bareduino328-barebones-microcontroller-guide/
Only place the Atmega on your board (picture 2)
Picture 3 and 4---Atmega328 with external 16Mhz crystal
Picture 5 Atmega328 minimal circuit
STEP 5: Target Atmel Microcontroller 1: Atmega328p (burning Bootloader and Uploading Sketches)
1- Connect the wires from the Leonardo to the atmega328 (please take a look to atmega328 pinouts these are the same with atmega168 -picture 1):
Atmega328 Arduino Leonardo
(in the picture 1 pins on black)(picture 2- 6pin ICSP)
RX pin 2-------------------------------------digital pin 0
TX pin 3-------------------------------------digital pin 1
MISO pin 18-----------------------------------ICSP pin MISO
MOSI pin 17-----------------------------------ICSP pin MOSI
SCK pin 19-----------------------------------ICSP pin SCK
RESET pin1-------------------------------------digital pin 10
And power pins 5v and ground.
Refer to pictures 3 and 4 for the final result
Burning Bootloader (if you bought the Bareduino or you are using a bootloaded Atmega328 skip this step)
*********IMPORTANT: additional step for Minimal circuit configuration*********
1- Go to http://arduino.cc/en/Tutorial/ArduinoToBreadboard and download the Breadboard.zip
2- Create a "hardware" sub-folder in your Arduino sketchbook folder (whose location you can find in the Arduino preferences dialog). If you've previously installed support for additional hardware configuration, you may already have a "hardware" folder in your sketchbook.
3-Move the "breadboard" folder from the zip archive to the "hardware" sub-folder of your Arduino sketchbook.
4-Restart the Arduino software.
5-You should see "ATmega328 on a breadboard (8 MHz internal clock)" in the Tools > Board menu.
******************Additional step finish here******************
1- Check the connections again
2- Select your board:
Atmega328 with external 16mhz crystal ----> Arduino Duemilanove w/ATmega328
Atmega minimal circuit without external crystal -----> ATmega328 on a breadboard (8 MHz internal clock)
3- The Serial Port should be the same as Arduino Leonardo
4- Select Arduino as ISP (Leonardo) in Programmer
5- Select Burn Bootloader at Tools Menu
6- If you get this message: Done burning bootloader, Success! (see pictures 6 and 8)
If you receive an error message, check your connections one by one and repeat the process.
Upload a sketch
1- Do not move your connections
2- Choose a sketch (look at picture 1, Arduino pin configuration in red)
3- Use Upload using programmer from the File menu, Done! (picture 9-classic blink)
STEP 6: Target Atmel Microcontroller 2: ATtiny84
1- Install the software support for the Arduino IDE from the core you chose.
2- Plug wires between (RX,TX, if available) MISO, MOSI, SCK,RESET, 5V and GND of the ATtiny (search for pinout from the Atmel datasheet) and your Arduino Leonardo.
REMEMBER: the RESET pin for the Leonardo is digital pin 10
3- Open a sketch
4-Choose the corresponding board. In my case, using the High-Low Tech Core, I am selecting Attiny84 (internal 8Mhz clock).
5- Select Arduino as ISP (Leonardo) in Programmer.
6- Use Upload using programmer from the File menu.
Important: Some chips have to be bootloaded when using the Arduino-Tiny Core. In that case use Burn bootloader before you upload a sketch.
Important, also: Cores use different pin configuration, you have to refer to their documentation when writing a sketch.
Example:Picture 2 is Pin configuration for ATtiny84 from the High-Low Tech Core and picture 3, from Arduino-Tiny Core.
STEP 7: Thanks!
This is my first Instructable so any comments, suggestions, criticism are welcome.
26 Comments
Vettel 7 years ago
If you use "upload" that way you upload to the Leonardo board, overwriting the Arduino as ISP scketch in it! You are not flashing the target chip.
Add this in your "programmers.txt" instead:
arduinoasispLeo.name=ArduinoasISP(LeoNardo)
arduinoasispLeo.communication=serial
arduinoasispLeo.protocol=arduino
arduinoasispLeo.speed=19200
arduinoasispLeo.program.protocol=arduino
arduinoasispLeo.program.speed=19200
arduinoasispLeo.program.tool=avrdude
arduinoasispLeo.program.extra_params=-P{serial.port} -b{program.speed}
SilvanM 8 years ago
Thanks a lot for this helpful instructable.
However, in Step 5 there to upload a Sketch you tell us to use the menu item "Upload using programmer" to upload a sketch. This does not work. It returns an error message: "Error while uploading: missing 'program.tool' configuration parameter".
If I use just "Upload" it works.
Can you tell me why?
arohkman 8 years ago
KlemenŠ1 8 years ago
if your IDE 1.6.4 software doesnt find the programmer Leonardo option, you need to past that text not in leofix folder, but go to hardware->arduino and find an existing programmers.txt file there, and paste that tet at the end of the ones already in.
AnujD 8 years ago
AnujD 8 years ago
thanks a lot!! made it with a little help from these guys
https://daflabs.com/arduino-leonardo-with-headers.html
TollerT 9 years ago
I Need help at Programming my Attiny85
I get this error when uploudin the Blink sketch to it via Arduino Leonardo:
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
UnitedElites. 9 years ago
Are you using the VCC and GND from the Leonardo? Try a different power source. In my case it was the other way around: I was using a battery and I had to feed my breadboard from the Leonardo. EVEN if the voltages were the same, the equipment didn't sync. Fiddle with this. Whatever works. In 2-3 days of searching I couldn't find anything else.
i know it may technically may not make sense, but, it's all i got as info
Also make sure your pins connect properly (I soldered my pieces, I do not have a breadboard), and some were not entirely well connected
scrlk 9 years ago
You can use different power sources but gorund must be connected so the 0v reference for the devices is the same when communicating.
carl.vandenzen 9 years ago
I don't understand step 5, the wiring from RX(pin2) to leonardo digital pin 0 and the wiring rom TX(pin3) to leonardo digital pin 1. These connections are not needed for programming the target (imho). I would suggest to mention the pin numbers for GND and VCC in the table, instead of the RX and TX pins.
scrlk 9 years ago
there are not necessary when programming via ISP but are used for serial communication
JihadZ 9 years ago
Hi
I would like to do the same but I want to use the Arduino Leonardo with circuit with atmega32u4 can you tell me how can I burn bootloader to the atmega
scrlk 9 years ago
Use any arduino board running the "arduino as isp" program or an avr programmer to burn. At the Arduino IDE, select the proper programmer and "Arduino Leonardo" ad board. Then click at "burn bootloader". It may take a couple of minutes.
If something is unclear do not hesitate to ask.
Lucif3r945 10 years ago
Great instructable. All info I could find prior to this was that you needed an arduino with removable IC (aka not a leonardo) in order to use it as ISP.
I tried this method on my leo yesterday and it worked fine :) Or well, I did have some initial issues with the atmega328 not being recognized....... But as it turned out I hadnt pushed it all the way down in the breadboard lol After I did that everything went perfect :P
RudreshPrabhu 10 years ago
Error while burning Bootloader.....
avrdude: stk500_getsync(): not in sync: resp=0x00
Help Required
creasty 10 years ago
cae2100 10 years ago
scrlk 10 years ago
Josehf Murchison 10 years ago
did you like the way I pined my LCDs
Joe
scrlk 10 years ago
