Arduino Mood Lamp Using BlinkM
Intro: Arduino Mood Lamp Using BlinkM
ThinkM is a new electronics company that has released new LED devices that can controlled from the computer using a simple interface program, and connector.
In this Instructable I will be teaching you how to control any ThinkM device that you may have rather than using the LinkM USB drive.
STEP 1: Parts List
1 BlinkM
1 LinkM (Optional)
1 Arduino Uno, Mega, etc.
4 Jumper Wires
1 USB A to B Connector
1 Breadboard
A Computer To Use
In This Instructable You Can Use Either The MaxM or BlinkM
1 LinkM (Optional)
4 Jumper Wires
1 Breadboard
A Computer To Use
STEP 2: Download Required Files
STEP 3: Electronic Configuration
Connect the Gnd wire to the - on the BlinkM
Connect the 5V wire to the + on the BlinkM
Connect Analog Pin 4 to the d on the BlinkM
Connect Analog Pin 5 to the c on the BlinkM
STEP 4:
Open the Arduino application and open the source code in the BlinkM Communicator Folder
Upload the source code to the Arduino device currently plugged in
Open the BlinkM Sequencer in the BlinkM Sequencer Folder
Click the Set Connection Button
Connect the Arduino with the Com Port currently used
Now you are able to sequence your own color code using the simple interface
When you are satisfied with your sequence make sure to click the Disconnect Button before exiting the application or the sequence will not loop
You Have Now Programmed Your Arduino To Control The BlinkM Device
STEP 5: Finished Product
The Finished Product Should Look Like This
